Tranny hunting? Try this!
Old 09-02-2010, 10:28 PM
R.T.D.H.S.P.'s Avatar
https://www.atsdiesel.com/PDF/120505...%2047%20RE.pdf
Tranny hunting can be a headache for all us 2nd gen people. Thought I would shed some light on my experiences which may help some of my fellow 98-02 people.
Ferrite chokes worked a while for me. So did cleaning grounds. Tried this and hasn't let me down yet. Feels like it should again!
If your tranny is hunting gears you may wanna give it a shot. When you take the time to examine what this fix is actually doing as far as the wiring goes, it makes good sense.
Remember that the wire from pin 3 (blue w/white stripe) on the APPS connects to the end of the wire for pin 23 (orange w/blue stripe) on the PCM that you make the cut on. The end of the orange wire w/blue stripe that runs to the ECM will no longer be connected to the PCM connector.
Old 09-03-2010, 06:45 AM
olddodgetrucks's Avatar
did mine 2yrs ago,works fine,solder connections.no more trans hunting
Old 09-03-2010, 02:09 PM
dkenny's Avatar
I just added the extra ground to APPS..problem solved. no wire cutting
-dkenny
mkeanglorldo56
01-05-2007 07:49 AM
Dennis
01-15-2005 01:32 PM
chaikwa
07-29-2004 01:34 AM
chaikwa
06-20-2004 08:58 PM
Quick Reply: Tranny hunting? Try this!
