Tranny hunting
Old Jun 19, 2004 | 09:53 PM
chaikwa's Avatar
Tranny hunting
I have a 98, 24 valve, DRW, 4X4 that has suddenlt begun to 'hunt' between 3rd gear and overdrive, (or lockup and unlocked), when traveling at a steady 38 to 40 mph.
Any ideas of what I might look for?
chaikwa.
Old Jun 19, 2004 | 11:21 PM
ratsun's Avatar
chaikwa
I had the same problem that started intermittantly and than got worse over time. After the first trip to the dealer they reflashed the ECM with a factory update (they said its very common in early 24V) All was ok for about 2 weeks then hunting(TC lockup) began again this time at all different speeds many trips to the dealer resulted in them changing the output sensor on the trans and all ok for 2 months now Check if your truck has the ECM update DC can tell from the VIN
Good luck
ratsun
Old Jun 20, 2004 | 03:12 AM
FastSS's Avatar
Look up APPS reset proceedure... mine did this for a while, I reset the apps and it was fine...
then I blew out third and reverse... obviously, its not so fine now
should it be anything worse, shoot me a PM I might have a good deal on a tranny for you.
Old Jun 20, 2004 | 06:54 AM
j-fox's Avatar
auto tranny
I see your post about trannies, and want to be on the list if you are going to sell it.
John
217-971-3988
Old Jun 20, 2004 | 08:34 PM
chaikwa's Avatar
thanks guys, appreciate the info. I'll look into the obvious things and let you know what I find.
chaikwa.
Old Jun 20, 2004 | 08:58 PM
Wolfeman's Avatar
chaikwa; this is a common problem caused by electrical noise spikes. It can be temporairly fixed by cleaning battery terminals and electrical grounds. Call DTT 1 866 504 4002, they will give you good advice and they sell a noise filter for about $40 which usually fixes the problem.
Tom
RedRacer44
Dec 10, 2007 11:09 PM
mkeanglorldo56
Jan 5, 2007 07:49 AM
Dennis
Jan 15, 2005 01:32 PM
chaikwa
Jul 29, 2004 01:34 AM
