Tranny Biuld
Old May 2, 2008 | 10:09 PM
daking's Avatar
Tranny Biuld
Hi Guys just looking for some advice
i finaly got some cash that i was waiting for to do my tranny with, i have a
A518 and i need to biuld it up to hold alot of hp and torque, like 600 to 700hp i know there is guys out there that have done this so im all ears to what you recomend for parts and things i should be doing
its a 4x4 and i want to keep the non lock up, i dont want to switch to the 47
also i wount be doing the work it will be my budy from the tranny shop, i just have to get the parts
thanks
joel
Old May 3, 2008 | 06:00 PM
bgilbert's Avatar
Not gonna happen in a 6000lb non lockup 600hp/1200ftlb+ 518 auto truck. You got two choices. One will be EXPENSIVE, one will be cheap. High dollar build will be a 47rh. Cheap and proven will be a shifter. Getrag.
Old May 3, 2008 | 09:09 PM
daking's Avatar
How much would a biult 47rh cost, i hear it isnt hard to switch just need some extra wires and a switch, right?
whats involved in switching to the getrag, seems like alot of work, im going to need a clutch pettle and stuff, any words from the wise on switching?
Joel
Old May 3, 2008 | 11:32 PM
rbrettctd's Avatar
I switched. Found a donor truck with every part I needed and got everything for the swap for $600. I bought new hyrdraulics and new clutch on top of that. $300 for hydraulics from dodge and then clutch of choice. I priced a built 47rh.....Billet everything from BD I believe was well over $6.5k.
Old May 4, 2008 | 08:34 AM
JD730's Avatar
I built the 47RH in my truck and I have right around $3k in parts in it. Billet input, 3 disc converter, valvebody, plus all the little fancy small parts I put in. And don't cut corners either, you'll probably change converters a couple of times to get one that works well with your turbos.
Old May 4, 2008 | 10:37 AM
bgilbert's Avatar
They summed it up right there. If you want to go further, you'll have to make a choice.
Old May 4, 2008 | 12:48 PM
daking's Avatar
thanks guys
both sound great but finding the parts up here will kill me even roted out trucks with 600000kms go for 2500 bucks, then a converter or dual disk
no matter witch way i cut it im going to spend 3000gs +, thats why i want to biuld my tranny, unless sombody has a tranny for sale that isnt to far out of the way then????,
like i might be making some big hp but its just a toy truck and i problay wont ever pull a sled with it, will a good torque converter and shift kit, work as long as im not always on it
Black Dog
Dec 3, 2009 08:18 PM
high bid
Aug 2, 2007 06:08 PM
ezdemon72
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
silverram323
24
Nov 9, 2003 07:48 PM
