towing temps stock
Old Oct 16, 2002 | 08:15 PM
thumbs's Avatar
towing temps stock
I have a '92 W350 Dodge Cummins 5sp with 354 rears. I just bought a fifth wheel camper that grosses at 11k. The truck is stock. I will be adding an afe air filter and cleaning up the exhaust. Will I be in any temp dangers such as EGT's? She pulls the camper pretty well but I do notice that I put the throttle on the floor when goin up a grade. I know this is probably normal but with a stock setup like mine are there any dangers?<br><br>Thanks for the info and help<br><br>Gary
Old Oct 16, 2002 | 09:49 PM
Bad B5.9's Avatar
Re:towing temps stock
Gary, when my truck was stock, (it's a '93), it would push the egt's right up past 1100 degrees easy, especially at lower rpms. I never tried to see how high they would go. It was o.k. above about 1750 rpm or so. One thing I did that really helped was install a 16 cm turbo housing. I also have a 4' exhaust. This brought the egt's down a good bit. That leads to turning the fuel up, and you won't believe how much nicer it is to drive. Clarence
Old Oct 17, 2002 | 06:53 AM
thumbs's Avatar
Clarence<br><br>Thanks again for the info. Yeah I was tryin to keep er stock. I was afraid that it wouldn't have enough to pull the fifth wheel before I got er. She ain't now rocket but she will pull er ok. I was trying to get out of &quot;bombin&quot; if I could. Don't want to hurt er though I love that truck.
Old Oct 17, 2002 | 07:43 AM
Bill1374's Avatar
Thumbs,<br> I'm a tad newer with a95 but my EGT would run about 1150 with a slightly heavier trailer on a hard pull. I would think you'll be OK stock but the guages, especially the EGT wouldn't hurt.<br><br>Bill
Old Oct 17, 2002 | 12:09 PM
AlK's Avatar
AlK
Gary,<br>If you find that the truck is starting to lug, then shift down into 4th gear this will bring the temperature down.<br>---<br>Al
Old Oct 17, 2002 | 03:04 PM
calvic's Avatar
I have a 92 and used to a Lance camper with every option available. It was one heavy mother. I had no problem hauling it. I did lose a O.D. carrier bearing which was fixed under warranty. I pull a 31 ft travel trailer now, no sweat.<br> JJ
Old Oct 17, 2002 | 06:22 PM
thumbs's Avatar
Hey thanks guys. I take it as long as I don't lug the engine I should be fine right? I guess keepin it in power band around 1800 rpm. should do it. <br><br>Thanks again<br><br>
by2005
Jun 3, 2005 09:15 PM
twhite
23
Jun 12, 2004 05:29 PM
Jim in Co
Aug 27, 2003 09:56 AM
awmasparky
Jul 15, 2003 02:19 PM
awmasparky
Jul 14, 2003 06:20 PM
