towing 10,000??
towing 10,000??
just towed my toyhauler empty, 10,000 pound bumper pull..
When i reprogram my smarty i have to unplug my fass 150, or it screws up the programming. not every time but just sometimes?
I forgot to plug it back in before the 8 mile drive! it ran fine and the egt's were good. sw 3 / timing 2/ rp default/tm 2/ waste gate off..
How could it do this without the fuel pump plugged in? was the injection pump working extra hard? did i screw it up??
Not true. The design of the canister LP meant that it would shut down if the pump failed. The in-tank is designed so that it doesn't shut down. Lack of fuel will not harm the CP3, as its been said the dmax CP3 doesn't use a LP.
Jim O
Your CP3 will pull fuel, but if there is a restriction in the line that won't allow it to thats another story. The CP3 is designed to pull fuel, Bosch specs for the CP3 are -5 to +15 psi.
That's the first I have read about the intank pump working that way. Almost makes me wish I had one. LOL I keep a spare canister mounted unit with me at all times. I guess that's a smart move....
