Top speed with 35s
Old 03-31-2006, 05:51 AM
SmokinDodge12V's Avatar
Top speed with 35s
What should my top speed be with 3.73s with 35s and a 6spd be the most I could get was like 102 at 3200 rpms my 5spd with 245s was like 108 at 3400.
Old 03-31-2006, 06:59 AM
2-Stroke's Avatar
i got 4.10s and an auto with 305s and the max I can it on flat roads is 116mph sustained.
prior to that i had the 265s and could only reach 108mph.
I got an excel spread sheet with formulas to compute your effective speed... I will try and find it and get it up for all to use...
Old 03-31-2006, 07:04 AM
2-Stroke's Avatar
Ok, this is where I got the spreadsheet from:
http://www.klenger.net/dodge/general...calculator.xls
Old 03-31-2006, 07:12 AM
Nate-03 D's Avatar
Took mine up to nearly 110 the other night with my 35's. Took a while to get there though.
Old 03-31-2006, 11:57 AM
According to that chart the revs per mile for a 315/70R17 should be 586.93 but when I looked it up for the 315 BFGs I have it says 601 revs per mile which is what I have my speedo set at right now which one should I go by. That chart also says that at 2000 rpms it should be 75mph my speedo only says 65.
Old 03-31-2006, 01:05 PM
2-Stroke's Avatar
How accurate do you really think BFG's info is? Go out and measure your actual height and look at there advertised height and tell me there isnt a difference... I bet that chart is closer than you think... I know it specs out really close from my expierences.
Old 03-31-2006, 03:07 PM
I checked some sites and they also said 587 so thats what I will use, so if my speedo was that far off I was going more like 120 at 3200 woops.
Old 03-31-2006, 03:47 PM
Mexstan's Avatar
I know my truck with the 315's gets up tp 100 mph quite fast but am afraid to go any faster on those tires. What is the max speed rating for the BFG 315's?
Old 03-31-2006, 11:24 PM
Swamp_Donkey's Avatar
With my 04.5 I had on BFG 285's....... 6 speed with 3.73. 109.6 MPH was all it would do. This was done with a GPS. No way it would do anymore. I had it pinned for about 10 seconds trying to get it all!
Old 04-01-2006, 11:28 AM
IntakeRacing's Avatar
i'm an auto with 3.55's and 315's and i can just touch 200km/h
Old 04-01-2006, 03:04 PM
Well I did another run with the new speedo calibration 110 was all she would go it was like there was some kinda speed limiter or something becuase I still had plenty of rpm left, I didnt think these trucks had speed limiters.
Old 04-04-2006, 10:02 PM
BigDan's Avatar
110mph in a 03 6 speed w/ 3.73 on 35" Toyo MT done on GPS. It took forever since im stock.
Old 04-04-2006, 11:45 PM
no_6_oh_no's Avatar
Yes, they have a speed limiter.
Old 04-05-2006, 08:33 AM
2-Stroke's Avatar
How then can I get 116mph sustained outta my truck on a flat road?
Could you possibly have been going up hill abit... or even a head wind... both would contribute to a lack of top speed.
Old 04-05-2006, 12:15 PM
I dont know but before I did the recal for the 35s it would only go to 100mph both times were done on flat straight away.
Quick Reply: Top speed with 35s
