too hot
Old Nov 15, 2008 | 02:57 PM
mcclain_90's Avatar
too hot
ok im realy new to this i just bought a 1990 ram le 250 pick up, single cad worn out auto trans, 35 in toyos, k&n intake, 93 head, 3,000 gov spring, 60 pound springs, just put new injectors in her, has gauges tac, pyro, boost, trans, 330k on her and going. the pump has been twecked, dont know how much? it runs at 900 degs, at 70 mph at 10 psi, if i mash it im at 1200 degs at 50 mph i know thats not right, a guy told me i had two injectors bad so i bought new, and put them in and its worse, it not hardly driveable, i hit a little hill and she heats and i have to back off of her, to a crawl, any ideas?
Old Nov 15, 2008 | 03:54 PM
Is your egt probe before or after the turbo? this makes a substantial difference in answering your question.
Old Nov 15, 2008 | 04:05 PM
Ace's Avatar
Ace
10lbs. boost cruising at 70 is a little high. Sounds like the tranny is struggling to turn those toyos.
Old Nov 15, 2008 | 04:56 PM
loch's Avatar
Try backing off the fuel screw a tad and bump the timing as well. Ace is right though the boost is high, mine barely registers at highway speed. The simple fact is you have more avalible fuel than you do air, either raise the air (turbo) or drop the fuel.
Where is your pyro probe ? before or after the turbo.
Old Nov 15, 2008 | 04:58 PM
How's the air filter look? What exhaust is on the truck?
Old Nov 15, 2008 | 07:37 PM
Philip's Avatar
Ace read his truck spec's. 90 model auto no OD. That means 3:07 gears with tall tires. Around 70 MPH the engine is running very close to 2200 RPM or so. So the boost numbers would be about right for that speed.
Turn the fuel screw back out some. That will lower the EGT at the throttle setting your using for 70 MPH.
A 4" exhaust will drop EGT's around 100 degrees at WOT.
Up grading to an intercooler would help a lot.
Old Nov 15, 2008 | 08:18 PM
mcclain_90's Avatar
some how i burnt my old one up, it was isspro i think, i have a sw now and it 2 weeks old, and it before the turbo
BearKiller's Avatar
These new injectors may be the key issue here.
If I read this right, someone's diagnosis was "two bad injectors", so you replaced ALL of the injectors with a new set, right ??
What brand and type injectors did you install ??
If you got ahold of some kind of race-horse injectors, then that is the problem.
The reason I say that is you state that after the injector replacement, the situation got a lot worse.
I suspect that these new injectors are dumping in a bunch of fuel that the rest of the engine is not equipped to handle.
Old Nov 15, 2008 | 08:23 PM
mcclain_90's Avatar
yeah i replaced all. there still bosch injectors from industial injection in utah the said there just a slight increase from stockers, another thing i noticed is the old ones where gumed up with build up over the holes so i dont think they where working great
Old Nov 15, 2008 | 08:27 PM
mcclain_90's Avatar
tranny
i have i brand new 46he or hr i cant renember witch one, new toque converter, but ive been look around and cant find a 94 style flex plate, when i find one ill change it i have every thing else
Old Nov 15, 2008 | 08:29 PM
mcclain_90's Avatar
its stright throght 3.5, and a k&n off a 05 dodge cummins
Old Nov 15, 2008 | 08:35 PM
mcclain_90's Avatar
could my turbo be trowing in hot air? i would i tell? it boosts up to 28 psi.wheres the stock setting for the fuel screw
Old Nov 15, 2008 | 10:52 PM
DodgeFreak's Avatar
It's probably an RH depending on the year what year did it come out of? you'll need the RH
Old Nov 16, 2008 | 02:23 PM
loch's Avatar
Yes the turbos adding hot air, and lots of it. Until you get an intercooler and a turbo it will run warm.
Just turn power screw out a bit until your egt's are more agreeable, you can turn it back in when you have an intercooler and a better turbo. Try 1/2 a round at a time, when temp drops to where you can live with it stop. Also the 1/8 inch timing bump helps with egts a little.
At 70 in mine im only 700 and i dont have O/D,
Old Nov 16, 2008 | 02:28 PM
Richie O's Avatar
366 Spring Chicken
I believe a timing bump must hide or fool the egt's. Does anybody else think this? I feel if the fuel fires earlier, then the piston is in the heat / fire longer. More heat must get to the pistons with advanced timing.
