Tires upgrade for '03
Old 07-03-2003, 08:17 PM
shaft's Avatar
Is it true that a stock 4x4 2500/3500 single rear wheel truck can accomodate up to a BFG All Terrain 315/70-R17 on the stock 17x8" wheels with no clearance problems? I heard some have rubbing problems. Is the leveling kit a must? Please clarify. Thank you so much.
Vince
Old 07-04-2003, 02:18 PM
LinearX's Avatar
Re:Tires upgrade for '03
I've got 315/70/17 on my stock wheeled, stock height 4x4 and don't have any problems for the most part. If I am full lock turning to the driverside, I have a slight rub on the frame put since I'm hardly at full lock I don't worry about it much. For the most part I think you should be ok, but every truck is a bit different.
Old 07-04-2003, 03:08 PM
Mexstan's Avatar
LinearX, when you changed over to these bigger tires what differences did you find? EG, has your fuel consumption improved? Has acceleration decreased noticably? Has the ride changed? If so, how?
Old 07-04-2003, 03:27 PM
shaft's Avatar
[quote author=LinearX link=board=17;threadid=16661;start=0#156565 date=1057346331]<br>I've got 315/70/17 on my stock wheeled, stock height 4x4 and don't have any problems for the most part. If I am full lock turning to the driverside, I have a slight rub on the frame put since I'm hardly at full lock I don't worry about it much. For the most part I think you should be ok, but every truck is a bit different.<br>[/quote]<br><br>Thanks for the response. How's the ride?
Old 07-06-2003, 12:43 AM
LinearX's Avatar
I think the ride has improved over the Michelins probably due to more sidewall to absorb shock. Fuel milage for me hasn't changed much. I get around 17.5-18 mpg but I drive at 80+ on the interstate. As far as acceleration going away, I've got the 3.73 and I can tell that taking off in second gear is bit different but it's not horrible. All in all, I'm happy with the change.
Old 07-06-2003, 08:01 AM
shaft's Avatar
[/quote]
This maybe a stupid question but a lot of people are saying that these trucks rolled out of the assembly line built differently (specially in regards to the tire rubbing when ugrading the tires. some have problems some don't) . How is this posssible when they have a protocol to follow, use the same parts and other obvious reasons. Is there an explanation to this ??? I just don't believe that this is possible. If it is, please clarify. Thanks.
Old 07-06-2003, 08:32 AM
DF5152's Avatar
depending on options there are probably several sets of front springs this where probably where the diference comes in...
Old 07-06-2003, 10:00 AM
DockHigh's Avatar
I believe the snow plow prep group option comes with stiffer front springs. I have this option and just put a set of BFG 315's on mine. No troubles so far.
Old 07-09-2003, 12:17 AM
Matt400's Avatar
[quote author=DockHigh link=board=17;threadid=16661;start=0#157077 date=1057503623]<br>I believe the snow plow prep group option comes with stiffer front springs. I have this option and just put a set of BFG 315's on mine. No troubles so far.<br>[/quote]I have heard that the &quot;snow plow prep&quot; trucks set level. My truck does not have that and set 2.5&quot; higher in the rear, I have since pulled out 1.25&quot; to get rid of the &quot;stink bug&quot; look.<br><br>Anyone find aftermarket wheels that have the correct off set??
Old 07-09-2003, 07:28 AM
DockHigh's Avatar
I don't believe the front end sits any higher than the non snow plow prep group trucks. It seems just as 'unlevel' as the rest, until I level it out with a load ;D Been throwing around the idea of a leveling kit but don't want to regret it down the road when I load it up. Nothing looks worse than seeing these big trucks with sagging rear ends
chrisminx
07-07-2010 06:48 PM
1320
05-29-2009 10:24 PM
sakisaki400
23
12-31-2006 10:17 PM
Captain
09-09-2005 12:16 AM
Quick Reply: Tires upgrade for '03
