tire psi
Old 12-15-2008, 04:52 PM
Silver R/T's Avatar
tire psi
What tire psi should I be running in my tires, they're stock size for 01 3/4 ton which is LT2658/75R-16's
Old 12-15-2008, 05:12 PM
GAmes's Avatar
There is a tire pressure/load chart on a couple of tire manufacturers web sites. Weigh each axle and go from there. FWIW I run 65 psi on the front tires and 55 in my duels. I get about 120k on the fronts and 100k on the rears with even wear all the way across.
Old 12-15-2008, 06:29 PM
Busboy's Avatar
Tire size will be in the door jamb.. my 2001 2500 QC is LT245/75R/16 and 65 in the front, and 60 empty/80 loaded in the rear.
Old 12-15-2008, 06:47 PM
atc250r's Avatar
Whatever you run them at you shouldn't exceed the pressure listed on the side of the tire. I have "D" range tires on my truck now for the winter and the manufacturer rates them up to 65psi so I run that front and rear. I don't haul anything that heavy that their D rating will be a problem for me.
John
Old 12-15-2008, 07:15 PM
infidel's Avatar
Same here on both my trucks.
If you want to get technical draw a chalk or paint stripe across a front and rear tire then take it for short drive on dry pavement.
If the mark wears on the outsides you need more pressure.
If it wears in the middle less.
Old 12-15-2008, 09:39 PM
DodgeDiesel61's Avatar
My tires (previous owner installed them) say no more than 50psi cold, so that is what I run them at. They are Toyo Open Country A/T, LT265/75 - 16.
As atc250r said, you should never exceed what the tire says on the sidewall for cold inflation pressure.
Old 12-15-2008, 10:51 PM
Dinner's Avatar
Are you able to read the cold psi ratings on the sidewall of the tires? If so just use that, the tires will have a single load psi rating. If that is worn off, then look in the glove box or the white sticker in the door jam.
Old 12-16-2008, 06:10 PM
sheriffav8r's Avatar
pump 'em up to the max tire sidewall pressure cold....
38 Cigarette
16
08-28-2015 11:27 PM
nrussell
07-23-2008 08:58 PM
Tommy93w350
08-07-2007 12:15 PM
Dave88LX
15
09-04-2006 09:30 PM
ckennedy
09-29-2004 05:06 PM
Quick Reply: tire psi
