timing all the way to the head need help with egt issues
Old Apr 19, 2009 | 09:43 PM
1985cucv's Avatar
ok guys i did a little experimenting with the truck in the mud this weekend. i realized that when i get stuck the egts just go through the roof like 1500 i really do not like that! so i was wondering if i timed it more would i lose more egts? also would this be a bad thing for what i intend to do with it i know timine boosts drive pressure which can be a bad thing as well? it will probably be a lot of wot with not a lot of movement. but im sure guys work their trucks this hard everyday.
also if you time it all the way to the head what do you do with the fuel line? mine is already tucked right up there now thanks a lot guys
Old Apr 19, 2009 | 09:46 PM
TIMMY22's Avatar
Keep the tailpipe out of the mud!
Old Apr 19, 2009 | 11:53 PM
gear jammer 91"'s Avatar
Adding an intercooler would help. When I put my pump against the head I just slightly loosened the boost line out of the head and then adjusted the pump. The boost line just bent itself as needed for the pump movement.
Old Apr 20, 2009 | 11:45 AM
1985cucv's Avatar
yeah i have the intercooler off a 2nd gen it will just be some fabrication! but i suppose.
but how many egts would i lose with timing it all the way to the head? a hundred or so, it is about 1/2 inch away now
i was talking about the fuel line on the front of the pump not the boost line
Also i have a stack and the mud dont get up there well not most of the time!
Old Apr 20, 2009 | 12:08 PM
stackx2's Avatar
when i put mine to the head it lowered my egt's but not dramaticly, and it sounded like a 24v. i would be trying to put that 2nd gen intercooler in if i were you, that should help alot.
Old Apr 20, 2009 | 01:48 PM
crewcabxlt's Avatar
really advanced timing raises cylinder pressure and can cause head gasket to blow pretty quik. the intercooler really adds more usable power, worth the effort.
Old Apr 20, 2009 | 06:11 PM
I just let my fuel line hit the head. You might be able to bend it down a little bit if you need to. If I remember correctly I lost about 100 degrees maybe a little more. Really advanced timing usually means advancing the pump gear by one tooth, I wouldn't worry about the head gasket with the pump against the head, but that's me. On the innercooler, have you looked at any of the water to air units?, something like that might fit your needs a little batter.
Old Apr 20, 2009 | 07:12 PM
1985cucv's Avatar
either that or i will just turn down the fuel. the reason i dont want to use the i c is because i have to pipe the thing and then get a new radiator and move a battery etc and fab it all up again i realize that it is a big ordeal i would like to find a water one but they are usually expensive from what i have found
Oh and i am somewhere in the neighborhood of 40 psi so more timing means higher boost right which equals blown hg right?
Old Apr 20, 2009 | 10:06 PM
crewcabxlt's Avatar
more timing can reduce boost,in testing i found it can slow spool-up a little too, but its the cylinder pressure that gets the headgasket. also if you have a original non i/c gasket they are more prone to fail due to different design. intercooled had a better one from factory. brief 1500* egt spikes on a play truck may not be detrimental.
Old Apr 20, 2009 | 10:55 PM
That's what I've seen with my truck also.
Old Apr 21, 2009 | 05:36 AM
1985cucv's Avatar
ok i ll juice the timing a little more to make sure she is ok also would bigger electric fan reduce heat i saw 225 temp on the gauge that is a first for me
Old Apr 21, 2009 | 07:35 PM
I believe flexalite makes an electric fan that is made to cool a diesel, it should help.
Old Apr 21, 2009 | 07:54 PM
Dean Snow's Avatar
I noticed that when I had my timing bumped up a bit that my engine water temp would be higher and my EGTs were down. So i went back to no timing because when I haul it was horrible. Its a lose, lose situation for me.
Old Apr 21, 2009 | 08:14 PM
ofcmarc's Avatar
Bend it out of the way or get a Big line kit and reroute it.
jmd4993
Jun 22, 2013 07:36 AM
92smokin blacky
Mar 10, 2011 09:30 AM
steveh1155
Aug 26, 2007 09:01 AM
latitude500
Apr 3, 2007 10:49 AM
