throwing code p0217
Old 09-10-2009, 10:04 AM
rjm022's Avatar
throwing code p0217
throwing code p0217-decreased engine performance due to engine overheat condition. water pump was replaced a couple of weeks back due to it leaking. truck never overheated. coolant level is full and coolant is fresh. truck is running fine-no symptoms. what gives? anybody know exactly what this codes means and where to look for a problem??? thanks.
Old 09-10-2009, 10:08 AM
rich's Avatar
check the plug connection that leads to the fan mite be loose or corroded
Old 09-10-2009, 10:55 AM
rjm022's Avatar
good idea-will do-thanks
Old 09-10-2009, 06:38 PM
rjm022's Avatar
i been thinking about that and asked a buddy about it, and realized that it's a clutch fan so there is no electrical connection???/correct????anymore ideas???
Old 09-10-2009, 10:31 PM
Det 1's Avatar
The fan clutch does have an electrical connection. The wire loom comes out of the fan clutch, runs down the back side of the radiator, and makes a connection underneath the fan shroud near the driver's side of the vehicle. According to my mechanic the fan speed varies with temperature and engine rpm, all monitored by electronics. Mine failed recently and it was a $500+ fix, including labor.
Old 09-11-2009, 12:29 AM
rjm022's Avatar
thanks-will check out tomorrow!
Old 09-11-2009, 10:14 AM
rjm022's Avatar
stumped-i checked the plug to the fan-everything good. unsnapped it-looked brand new inside. fan turns freely when truck is cold-dont feel any play. buddy of mine plugged in his snap on scanner last night-obviously code p0217 came up-said something to the affect of-check integrity of the cooling system-where to next?????
Old 09-11-2009, 10:48 AM
rich's Avatar
bad sending unit maybe
Old 09-11-2009, 11:00 AM
dieselfreak21's Avatar
Has it ever been flush?
Old 09-11-2009, 12:02 PM
rjm022's Avatar
yes- coolant was flushed and new thermostat put in one year ago. could this code of been thrown when the original water pump started to leak??
Old 09-12-2009, 01:09 PM
rich's Avatar
yea maybe try to clear the code and see what happens
Mark Hodowanec
08-26-2009 05:55 AM
Mark Hodowanec
08-24-2009 07:00 PM
hotdram
06-20-2006 10:16 PM
Quick Reply: throwing code p0217
