I think my vp is dead!!!!!
Old May 27, 2007 | 03:35 PM
FDPOWER's Avatar
Comming home tonight the truck shutoff on me n had codes p1691,p1690,p0370 and p1693. I think the vp has done me in. Im only at 110805 miles. I get it home buy the grace of god . I started it this morning an it would run an start to shut on an off like it was sucking air then shut off. SO if it is bad what injection pump do you think i should get?Also are these the codes make the vp dead?
Old May 28, 2007 | 01:11 AM
TLDC's Avatar
This is what I found.....might want to double check!!
0370- Timing reference high resolution signal A malfunction
1690- Wastegate solenoid circuit malfunction
1691- Turbo pressure control solenoid circuit malfunction
1693- Turbo charge control circuit malfunction
Hope this helps some!
Old May 28, 2007 | 10:17 AM
bob4x4's Avatar
0370 is ijection pump speed signal lost----------replace the injection pump.
1691 is inj pump calibration error---------------replace the inj pump
1690 inj pump speed does not match ecm speed replace inj pump
1693 companion code---------look in pcm for other codes
Be very careful there are many code definitions out there that are incorrect.
Good talking to you yesterday,too bad about the reason.Sorry,but if you own a vp 44 you will be replacing one,it is just a matter of time.
Bob
Old Jun 2, 2007 | 11:21 PM
FDPOWER's Avatar
gOOD TALKIN TO YOU TOO BOB. I PUT THE BYPASS HARNESS ON IT JUST GET THE COMPUTER OUT OF THE EQUATION. AN YEP ITS THE VP-44. SOMETIME I HATE WHEN IM RIGHT
Old Jun 4, 2007 | 12:59 AM
EverydayDiesel's Avatar
bob where did you pull these codes from?
is there a site with the correct ones listed?
Apocalypse
Jul 1, 2008 12:09 PM
600 Megawatts
Mar 26, 2008 07:09 PM
Jvenne86
17
Mar 20, 2007 08:27 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
