Thermostat
Old 03-29-2007, 12:12 PM
dIlLiGaF's Avatar
Question Thermostat
I need a little info please. It's time to change the tstat and coolant. Will on the quickserve site i noticed they list a tstat and a seperate seal, the one I bought from cummins has a seal built onto the rim of the tstat. Can anyone tell me if the second seal is needed or not? I would also like to chemiclly flush the cooling system, anybody have any recommended products for this?
Alex
Old 03-29-2007, 12:28 PM
olwhitey's Avatar
i dunno about the coolant or anything but i put a thermostat in mine from cummins jus like u said with the rubber seal around it and it works fine for me, no other seal or anything. no leaks either. hope this helps
Old 03-29-2007, 01:30 PM
cumminspower79's Avatar
Not to hijack, but does anybody have that cummins part number, I also need to service my cooling system. Thanks
Old 03-29-2007, 01:50 PM
99globalwarmer's Avatar
i believe you are fine. but get a lower thermo 180 instead of 190 stops all the fluctuating temp.
Old 03-29-2007, 01:57 PM
dIlLiGaF's Avatar
Part number from cummins is 3946116. They only had a listing for 180 degree thermo for my cpl.
Old 03-29-2007, 02:42 PM
new2ctd's Avatar
Dodge sells them seperate. tstat and then the seal. That seal is $11 by itself at the dealer.
Cummins sells it as a kit with the seal already attached to the tstat.
This is the standard part# 3967195
Old 03-30-2007, 02:04 PM
RowJ's Avatar
Originally Posted by dodgepower79
...does anybody have that cummins part number, I also need to service my cooling system. Thanks
Cummins 180* T-stat (I recommend it also) - PN 3967195
RJ
Old 03-31-2007, 11:57 PM
bobbywebb's Avatar
Get the 180 t-stat, I just did, and then go to wal-mart and get the fleetguard antifreeze. You will notice a difference, just did mine 2 weeks ago and wish I would have done that a year ago. No more watching the temp guage go up and down all the time.
Old 04-01-2007, 04:57 PM
D2 Cat's Avatar
I've got thermostat, genuine cummins parts, on the box says 05014568AA. The rubber seal on the thermostat says 3934379, "towards radiator". The guy I got it from said he used the same number in his '96. Is this an old number or a part that won't fit?
Old 04-02-2007, 07:25 AM
RowJ's Avatar
That may be the 190* T-Stat.... which originally came with our trucks, and was redesigned by Dodge...for faster warmups.
If towing a lot, working/racing truck hard or living in the heat in the south, many have had better luck with the 180* T-Stat. It prevents the coolant temps from climbing easily and becoming the limiting factor.
RJ
Old 04-03-2007, 04:36 AM
qwest's Avatar
Any MPG lost with the 180 deg vs 190 deg Thermostat?
Old 04-03-2007, 07:21 AM
RowJ's Avatar
Not by me, or anyone I've spoken with. Theoretically possible, I suppose, in cooler climate, but not with our mild winters and 7 months of summer!
FYI - for those interested. I have heard some crazy variations in price for the Cummins PN 3967195. Should be in the $30-40.00 range from any Cummins parts place. IMO, this is not a part to save a few bucks on from the local parts place.
RJ
Bookshelf
05-30-2009 01:17 AM
mechanic
03-25-2003 08:45 AM
BigBlue
12-10-2002 10:55 AM
Crazy Horse
11-16-2002 01:00 AM
dart racer
11-11-2002 10:10 AM
Quick Reply: Thermostat
