Sway Bar end Links?
Old Jun 25, 2006 | 02:10 PM
68dodge's Avatar
Sway Bar end Links?
Anybody know who makes heavy duty sway bar links? Mine seem to have a little bend to them after 10000 miles with the lift kit and 35s. The Skyjacker kit did come with a sway bar drop kit.
Old Jun 25, 2006 | 02:16 PM
Stealth Mode's Avatar
bent ends
mine do the same thing dude.. have the drop down bracket and still did it.. i saw a friend's truck with the superlift 6" kit and had the long sway ends installed.. i guess superlift does it right good luck
Old Jun 25, 2006 | 02:22 PM
nriver's Avatar
lorenz, Carli....
http://lorenzindustries.com/fox.shtml Down near the bottom. Drop Sean a email for a info
http://thecarlisuspension.com/display_part.php?prt=6
Old Jun 25, 2006 | 03:16 PM
RamWheelsBy4's Avatar
I have had only ONE DW issue in 50,000 miles. It was caused by stupidity(mine) and combination of other contributing factors. That one time bent both of my stabilizer bar link rods. They do seem to be undersized even for stock suspension. One good out of control bouncing caused this.
Old Jun 25, 2006 | 04:01 PM
Raspy's Avatar
From: Smith Valley, NV (sometimes Redwood City, CA)
nriver,
Thanks for the link to the Carli sway bar links! I thought only the Dodge ones were available and why replace junk with junk?! Cool.
John
Old Jun 25, 2006 | 04:24 PM
Ramtough's Avatar
I have both bent and the drivers side is at least at a 45 degree angle. that was done stock on a hard hit. great links.
Old Jun 25, 2006 | 07:26 PM
Jme's Avatar
Jme
Not really a truck mech. and don't know alot about it. (this is one of the reasons for joining to learn more about the Dodge) Anyway, maybe I have the control arm and the sway bars confused. Anyone have a pic of each installed on the truck? The part in queswtion is the bar that helps (or responsible) for turning the weels in the front. On mine, the bushings are pancakes now and I have one hellva squeak and I am trying to find out if this might be the reason. Thanks...Jamie
Old Jun 25, 2006 | 09:57 PM
nriver's Avatar
Control Arms
Sway bat below the shock resi.
end link at the end
Old Jun 25, 2006 | 11:28 PM
My mistake, I thought you meant the Stablizer Bar Link rods.
Bikinaz
35
Oct 14, 2010 03:36 AM
jk6140
Mar 9, 2008 08:22 PM
oldblues
Jun 25, 2007 11:12 PM
Inferno Ram
Jun 11, 2006 10:53 AM
