Suspension Gurus help needed.....
Old 04-03-2007, 07:56 PM
CDoskocil9's Avatar
Now I think I want the truck a little taller.... It is a 2006 Dodge Ram 2500 with the Kore Chase System Installed..... I was thinking of maybe adding a 1inch leveling kit up front and then adding the bottom overload back to the rear which should keep my truck level....... The problems I see with all this are the control arms and the track bar which are both stock..... Will I be ok with the stockers for awhile or will they both need to be changed with another inch of lift..... By the way where can I get a 1inch leveling kit......
Thanks for any help
Old 04-03-2007, 11:40 PM
Cowhand's Avatar
1" won't make a big difference with the front....it'll kick the axle to the left slightly and pull the tire a little closer to the fender. If you can find a 1" coil spacer....you can jack the frame up an inch and see how your clearances look. Factory CA's are okay up to 3-3.5". Eventually you'll want some 1/2" longer CA's to push the axle forward.
Putting the overload back in the rear spring pack isn't worth the inch you'll gain, it'll kill what ride quality you have.
Do you have KORE add a packs in the rear?
I'd recommend leaving it alone until you get the track bar, then get the 3" springs from Sage Carli or Don Thuren. Sage runs a 37" tire with his front spring and until recently, was doing it with the factory control arms. You'll like Sage/Don's springs better too, lighter spring rate works way better. If you don't have the add a pack, get it- that'll give you another 1" or so additional ride height and get the rears working like they should.
F/R springs will run you under $800 and it'll ride light years better, as well as perform to the limits of your shocks.
Old 04-04-2007, 07:50 AM
nriver's Avatar
not sure if you will have shock issues going with 1" more lift. There may be some issues there. bottom out or over extend. Not sure on the latest kore/fox kit.
You will get 1 more inch when you go to the 37s, im sure you know that. Looks like you are also going with the glassworks fenders. These typically take care of needing longer control arms. They will also make it look like you have more lift. Higher upper fender line. Post some pics when you get that done. Ive been thinking about them.
The track bar is a good idea if you start having problems.
I currentley run 37s with 3" springs up front. Stock control arms and track bar. I did mod the fenders to eliminate some rub.
I think it sits fairly level with this setup. If you have not seen pics, i will post some.
Old 04-04-2007, 08:12 AM
Speed Shift's Avatar
You will be fine with 1 more inch of lift.
Old 04-04-2007, 10:31 AM
ptgarcia's Avatar
Now would be a good time to replace the track bar. And Don may be able to help you with 1" spacers.
Don't add the overload back in. If anything add a 1" block or have the overload cut down into a block.
Old 04-04-2007, 01:14 PM
Lsufan78's Avatar
i agree with pauly...just have your overload cut down to about 8"s long and that'll give you the 1" you need. that's what i did with my carli add-a-pack.
later, dustin
Old 04-04-2007, 02:05 PM
TX_Diesel's Avatar
won't that add more axle wrap. I would think if you want to do it right, get a new spring pack that gives you the amount of lift you desire with the best possible ride quality and least amount of axle wrap.
2 cents
Old 04-04-2007, 02:24 PM
ptgarcia's Avatar
It's just an inch so I don't think axle wrap will be a problem, especially if he has the KORE spring pack.
Old 04-04-2007, 05:18 PM
CDoskocil9's Avatar
Yes I do have the Kore spring pack........... My setup rides great off road but man these Kore coils are stiff..............Thanks for the help guys
Old 04-04-2007, 10:16 PM
Lsufan78's Avatar
don't know why i didn't think about it earlier, but you could also get don to make you a longer shackle.
later, dustin
Old 04-05-2007, 12:22 AM
kurt b's Avatar
Cool Kore Suspension
Hey CDoskocil9 how's it going, I was under the impression that the Kore suspension not only dramatically changed the ride and handling offroad but gets rid of that nasty freeway hop at around 70mph caused by the overload spring. With the mini deaver spring pack it should ride great. Are the front coils stiffer than stock? I thought they were progressive rate? I was hoping to add the Kore Recon or Chase suspension to my truck but if it rides like you say, I'm wondering if it is worth the money? What do you think? kurt b
Old 04-05-2007, 12:34 AM
ptgarcia's Avatar
Forget about KORE. I'd look to Don Thuren or Sage Carli.
Old 04-05-2007, 08:30 AM
CDoskocil9's Avatar
Honestly I think I will have to agree with PTGarcia I have never ridden in a carli or thuren truck but I can tell you I have some ideas in mind including 3in shocks by next year and carli and don were the only ones willing to help with my custom setup therefore I wont be buying anymore KORE products........
On a side note I know for a fact that Kores Coils are stiffer than carli's........
Old 04-05-2007, 10:53 PM
kurt b's Avatar
Hey PT, thanks for the reply. I don't want alot of lift just a better ride and stance. I looked at the sites and their kits seemed very expensive, but were very complete. By the way, is that you hitting from the red tees there???
Old 04-05-2007, 11:08 PM
ptgarcia's Avatar
Yeah, that's me . We were camping, and you can't see it but our travel trailer was right there. That's a par three, so my boy and I were getting some shots in between the "paying" golfers . If you look closely you can see my son was amazed at my mad skills.....
samiam4
08-24-2013 11:19 AM
cowpie
11-19-2009 08:44 AM
ratsun
06-26-2009 10:39 PM
moparguy
04-07-2009 11:09 PM
singleturnout
01-07-2006 07:28 PM
Quick Reply: Suspension Gurus help needed.....
