Suspension Gurus help needed.....
Now I think I want the truck a little taller.... It is a 2006 Dodge Ram 2500 with the Kore Chase System Installed..... I was thinking of maybe adding a 1inch leveling kit up front and then adding the bottom overload back to the rear which should keep my truck level....... The problems I see with all this are the control arms and the track bar which are both stock..... Will I be ok with the stockers for awhile or will they both need to be changed with another inch of lift..... By the way where can I get a 1inch leveling kit......
Thanks for any help[guitar] |
1" won't make a big difference with the front....it'll kick the axle to the left slightly and pull the tire a little closer to the fender. If you can find a 1" coil spacer....you can jack the frame up an inch and see how your clearances look. Factory CA's are okay up to 3-3.5". Eventually you'll want some 1/2" longer CA's to push the axle forward.
Putting the overload back in the rear spring pack isn't worth the inch you'll gain, it'll kill what ride quality you have. Do you have KORE add a packs in the rear? I'd recommend leaving it alone until you get the track bar, then get the 3" springs from Sage Carli or Don Thuren. Sage runs a 37" tire with his front spring and until recently, was doing it with the factory control arms. You'll like Sage/Don's springs better too, lighter spring rate works way better. If you don't have the add a pack, get it- that'll give you another 1" or so additional ride height and get the rears working like they should. F/R springs will run you under $800 and it'll ride light years better, as well as perform to the limits of your shocks. |
not sure if you will have shock issues going with 1" more lift. There may be some issues there. bottom out or over extend. Not sure on the latest kore/fox kit.
You will get 1 more inch when you go to the 37s, im sure you know that. Looks like you are also going with the glassworks fenders. These typically take care of needing longer control arms. They will also make it look like you have more lift. Higher upper fender line. Post some pics when you get that done. Ive been thinking about them. The track bar is a good idea if you start having problems. I currentley run 37s with 3" springs up front. Stock control arms and track bar. I did mod the fenders to eliminate some rub. I think it sits fairly level with this setup. If you have not seen pics, i will post some. |
You will be fine with 1 more inch of lift.
Now would be a good time to replace the track bar. And Don may be able to help you with 1" spacers.
Don't add the overload back in. If anything add a 1" block or have the overload cut down into a block. |
i agree with pauly...just have your overload cut down to about 8"s long and that'll give you the 1" you need. that's what i did with my carli add-a-pack.
later, dustin |
Originally Posted by ptgarcia
(Post 1442907)
Don't add the overload back in. If anything add a 1" block or have the overload cut down into a block. 2 cents |
It's just an inch so I don't think axle wrap will be a problem, especially if he has the KORE spring pack.
Yes I do have the Kore spring pack........... My setup rides great off road but man these Kore coils are stiff..............Thanks for the help guys
don't know why i didn't think about it earlier, but you could also get don to make you a longer shackle.
later, dustin |
Kore Suspension
Originally Posted by CDoskocil9
(Post 1443524)
Forget about KORE. I'd look to Don Thuren or Sage Carli.
Honestly I think I will have to agree with PTGarcia I have never ridden in a carli or thuren truck but I can tell you I have some ideas in mind including 3in shocks by next year and carli and don were the only ones willing to help with my custom setup therefore I wont be buying anymore KORE products........
On a side note I know for a fact that Kores Coils are stiffer than carli's........ |
Hey PT, thanks for the reply. I don't want alot of lift just a better ride and stance. I looked at the sites and their kits seemed very expensive, but were very complete. By the way, is that you hitting from the red tees there??? :)
Originally Posted by kurt b
(Post 1445936)
