superlift dual pin rear blocks??????? Yay or nay
Old 09-06-2007, 11:56 AM
checkster's Avatar
Ordered my 4" superlift and when I unpacked everything I noticed the rear blocks look similar to the ones I had on my 96 ford. The new dodges have the dual pin leaves and the superlift block are just hollow and a large pin in the center.........wadafa? Have any pf you guys used these on the rear as I hav not taken my truck apart yet to install them? Did I get the right one or should the blocks have 2 small pin holes to locate on the spring?
Thanks for yer help,
Tom
Old 09-06-2007, 01:02 PM
Pooter's Avatar
Mine came with the hollow block as well, just the center pin/hole to locate it.
I dont like it.
I have a Carli minipack waiting to go on, just waiting for it to cool down before I tackle it...(Should give me an inch or so, and I can ditch the superlift block)
I still may need a 1" block, but ill get some 1" stock and drill some holes for 2 pins, I dont like the slack from the superlift blocks...
Old 09-06-2007, 01:52 PM
checkster's Avatar
so there is still a large locatiing hole in the rear axle mount to locate the block?
Old 09-06-2007, 01:57 PM
Pooter's Avatar
Yes.
The block just uses the large center pin/hole combo to locate the block, instead of the 2 pins that go thru the spring pack.
Ive had one rotate slightly, even though the Ubolts where as tight as possible.
Old 09-06-2007, 02:18 PM
benito's Avatar
Its easier to take the original overload springs and cut them down, making them a 1" blank...
Old 09-06-2007, 02:25 PM
Pooter's Avatar
You double them up?
I believe they are only 1/2"~ thick.
BrandonNucas10
11-19-2007 01:13 AM
rip 112
33
09-23-2007 09:36 PM
hipsi
22
08-10-2007 07:56 PM
D.Wiggs
68
10-31-2006 11:08 AM
Quick Reply: superlift dual pin rear blocks??????? Yay or nay
