Straight axle swap??
Does anyone know if a straight front axle off of a 74 3/4 ton chevy will square up on a 93 d350? If so what kind of hubs will be needed for the offset wheels? Thanks
By "straight axle", are you meaning a 4x4 front axle, or a genuine 2wd straight front axle ??
I am fairly certain that the spring-to-spring measurements on a GM 4x4, 1/2-, 3/4-, or 1-ton makes no matter, are all the same from 1967 to 1987.
I know they are the same from 1973 to 1987.
As for the DRW offset adapters, they can be found on just about any GM. Dodge, or Ford 4x4 front-end.
If you use the GM ones, you will also have to use GM wheels/plates on them.
The Fords and Dodges should use the same wheel.
Find a M1000 CUCV (6.2l) truck with the Dana 60 up front. Pull the 4.56's out and replace them with something higher and you'd have a tough axle.
GM only used Dana 60's in 1 tons' with certain GVW ratings, in the 70's and 80's...
PeytonMaterne
Aug 27, 2012 08:33 PM
rustydeeretech
17
May 21, 2011 03:05 PM
natlchamp2k4
Dec 6, 2005 09:38 PM
yarddog
Aug 30, 2005 09:01 PM
