stock turbo specs
Old Sep 15, 2007 | 07:43 PM
omaharam's Avatar
stock turbo specs
Ok, I spent about 30 minutes earlier today and about an hour just now trying to find specs for the stock turbo on 600 and 610 engines. I'm tired of looking so I'll just ask.
Now that ATS has finally released wheel specs for their turbos, I want to compare my 3k to a stocker to see which might be better suited for a compound setup with an s400.
I'm looking for the inducer and exducer size of the compressor wheel as well as the drive wheel. If I remember right, the exhaust housing is 9cm.
Thanks for the help.
Old Sep 15, 2007 | 08:30 PM
chrleb1's Avatar
The stock compressor wheel is a 62mm on the 04.5 and up turbos.
Old Sep 15, 2007 | 08:34 PM
t-boe's Avatar
If that's true, why are the aftermarket 62's so much better in the cooling department?
Old Sep 15, 2007 | 09:01 PM
chrleb1's Avatar
Because the trim might be a little different and or the exducer wheel is bigger. But it is true.
Old Sep 15, 2007 | 09:11 PM
Sloverado's Avatar
I thought that the 600/610 were 57mm.
Old Sep 15, 2007 | 09:41 PM
omaharam's Avatar
I'm pretty sure that's what I was told once when I called HTT last year. I'm just looking for a little more info than that.
chrleb1 - The exducer is not a wheel. Inducer and exducer reffers to the front and back edge of the wheel. So a compressor wheel has an inducer and exducer. For example, my 3k has a compressor wheel with an inducer of 57mm and an exducer of 81mm. The ratio of those two numbers is the "trim". So the 3k has a huge trim. What I am trying to find out is what the exducer side of the stocker is so I know how much less trim it has, as well as info on the drive(exhaust) wheel so I can compare it to the 3k. I know the 3k has a much larger exhaust housing.
Old Sep 16, 2007 | 03:07 PM
omaharam's Avatar
105 views and no one knows.
No wonder I couldn't find it when looking. Someone has to know. Guess I can try to call a couple turbo places and see if they can tell me.
Old Sep 16, 2007 | 03:33 PM
PourinDiesel's Avatar
More like 62mm @ the inducer.
Vendors will always try to say their turbo is "bigger" rather than just tell the truth. Heck sometimes they just dont know any better.
Ask the guys at HTT if they even have a Cummins in the parking lot....I bet the answer is no.
The advantage of the aftermarket turbos with 62 wheels up front is that they use a larger turbine housing and have larger turbine wheels that allow your engine to really breathe on the top end.
57/58mm is where the 03/04 555 turbo's were at (@inducer/compressor)
Old Sep 16, 2007 | 03:48 PM
t-boe's Avatar
With just a Smarty and an XZT would a 64mm be too big or just right? I wanted to go with a 62/13/71, but if that's not going to be big enough.
Old Sep 16, 2007 | 04:40 PM
A 62/13/71 or a 64/13 would be great even with stock injectors.
Old Sep 16, 2007 | 06:00 PM
chrleb1's Avatar
I know, i meant to say pinwheel. I do have a little understanding of turbos. Just a little tired lately. HTT and II 62mm turbos are the same compressor wheel with a larger exhaust housing and larger pinwheel. When you play with the 04.5+ turbos, they will flow like a hx-40.
Old Sep 17, 2007 | 07:17 PM
bigwheels94's Avatar
The guy I talked to at II said, with my mods, plus a smarty I should get a PS 6280CRL from them.They couldn't tell me what the specs were thoe.Would that be the one for me?
Old Sep 17, 2007 | 07:23 PM
bluechrome's Avatar
I love mine 48psi @ wfo @ 1325pyro
Big Blue24
Nov 27, 2008 12:36 PM
Muskys TD
Feb 24, 2007 09:37 AM
06RAMCTD
0
Dec 19, 2006 04:15 PM
wannadiesel
Sep 19, 2004 06:18 PM
Lil Dog
17
Sep 10, 2004 11:29 PM
