Stock turbo Specs on a 95????
Old 02-23-2007, 11:09 PM
Muskys TD's Avatar
Does anybody have all the specifications on the oem turbochargers that come on the 1995 trucks? Things like A/R of compressor and turbine? Inducer/Exducer size of both sides etc.....
Old 02-24-2007, 12:07 AM
TexasHardcore's Avatar
It should be an HX35W with a 12cm Turbine Housing.
Try the Holset site for all the specifics...
http://www.holset.co.uk/files/2_1_1_3-Holset%20HX35.php
Old 02-24-2007, 12:24 AM
TheBigNasty's Avatar
Early 95's had the WH1C, 95 was when they switched.
Old 02-24-2007, 09:03 AM
Fredbearstalksm's Avatar
Thats right, my 95 has a WH1C. You will just have to look on the turbo.
Old 02-24-2007, 09:37 AM
gman07's Avatar
I think the WH1C's and HX35's used on 12valves had the same compressor/turbine setup.
IIRC, the compressor inducer is 56mm, exducer is 83mm. The turbine inducer is somewhere around 70mm and the exducer is 57mm. Holset uses a cross sectional area instead of an A/R; the HX35 and WH1C should both have 12cm^2 turbine housings.
Big Blue24
11-27-2008 12:36 PM
omaharam
09-17-2007 07:23 PM
06RAMCTD
0
12-19-2006 04:15 PM
wannadiesel
09-19-2004 06:18 PM
Lil Dog
17
09-10-2004 11:29 PM
Quick Reply: Stock turbo Specs on a 95????
