Stock ride height
Old 02-01-2009, 02:14 PM
Big Red 97''s Avatar
Stock ride height
Does anyone know what the measurment is from the center of the hub to the fender lip on the front of a stock 2nd gen 2500 4x4. Or have a truck that they can measure it on so i can compare it to mine. Im trying to see if mine is stock or not. I was told it had a lift but im a little weary of that. Im putting bigger tires on and tryin to determine if they are gonna fit.
Old 02-01-2009, 03:54 PM
12v rollincole's Avatar
I know mines stock and im at 25.5 inches.
Old 02-01-2009, 04:08 PM
Doj Dewd's Avatar
just measured my truck in sig. with what are 'supposed' to be 2" leveling springs - the underside of the fender lip to the center of center cap is about 26.75". keep in mind i have stainless steel fender lip gaurds - so without them i would 'guess' that the measurement would be very close to 27". i know my truck is not stock height (which you were looking for), but now you can compare yours to measurements to a stock height as well as a leveled height. i also have no added weight over stock on the front end.
hth,
jason
Old 02-01-2009, 04:44 PM
FarmBoyAggie's Avatar
With bald 285/75 R16 tires and a Ranchhand full front replacement, my stock front end is 39.5" from the ground to the lip of the fender.
Old 02-01-2009, 06:25 PM
Thanks guys. When i bought my truck the guy told me it had a 3 inch lift. I agree that the rear is 3 inches higher because it has extra leafs under it but i measured my front from center of hub to fender lip and its 25 inches. I have a grll guard over the stock bumper and it dont weigh that much so My front is stock. Im thinking i will have to get a 2.5 inch leveling kit to help me fit these tires underneath it. Thanks again for the help guys.
Old 02-01-2009, 07:29 PM
Doj Dewd's Avatar
what measurement did you get in the back? i measured the rear while i was at it and got 27.5" stock height with factory overload
Old 02-02-2009, 11:27 AM
If i remember right it was like 29.5 or 30 inches.
Old 02-06-2009, 01:37 PM
It is 29 inches in the rear. I was lokking at my back axle where the leafs are at. There is about a 5 inch block between the axle and the leafs on both sides. Is that stock or is that some sort of lift block?
Old 02-06-2009, 05:04 PM
KHoffman's Avatar
The block between the springs and axle is stock.
Old 02-06-2009, 05:17 PM
Ok i just didnt realize the stock blocks were that big.
Ram95
03-20-2011 11:10 PM
6.7L OneTon
01-18-2008 12:20 AM
Sixpack73
01-22-2007 03:19 PM
chw
29
08-02-2006 11:31 AM
Quick Reply: Stock ride height
