Stock Fuel Plate
Old 09-18-2009, 09:18 AM
efbeason's Avatar
Stock Fuel Plate
Anyone know if a stock fuel plate from a 1994 manual tranny is the same as a 1998 auto tranny? I got kinda an emergency situation on my hands with the injector pump. So any info will be greatly appreciated. Thanks!
Old 09-18-2009, 05:04 PM
2wdcumns247's Avatar
im not sure but you could call a cummins shop and ask they would tell you right away
Old 09-18-2009, 05:55 PM
CTD12V's Avatar
No, I'm pretty sure the plates are different, not only because the hp ratings are different, but because the fueling rate has to be managed for an auto differently than for a manual. Keep in mind that the fuel plate affects fueling only at or near WOT--that's why it's called a fuel stop plate. If the AFC hasn't been gutted or drastically tweaked, it will be keeping the governor arm from contacting the plate anyway until a substantial amount of boost moves the AFC arm out of the way of the governor arm.
CTD12V
Old 09-18-2009, 08:24 PM
infidel's Avatar
They are different but no problem swapping in an emergency.
As said the plate doesn't do anything at all unless you are at WOT or towing heavy.
BCB
02-27-2006 08:53 PM
plow
08-07-2005 03:07 PM
plow
07-20-2005 08:40 PM
Rockcrawler
06-23-2005 11:40 AM
BLACK3500
08-10-2003 08:49 AM
Quick Reply: Stock Fuel Plate
