still have shift problems HELP!!
Old Apr 2, 2010 | 08:46 AM
dalewclark's Avatar
Angry still have shift problems HELP!!
had a shudder shift problem on my 2003 dodge 3500 and took the truck in to the trans shop because i didn't know how to change the Governor pressure solenoid and transducer got the truck back yesterday took 1/2 day cost $500.00 at first it was great shifted great then after about 50 miles it started with the same problem only worse. when you start out it will not shift from 1st to 2nd without giving a lot of throttle then 2nd to 3rd is the same and every time you stop it does it again unless you punch the throttle quickly and back off. called the trans shop and was told it could be a faulty Governor solenoid or transducer and if not they would have to go into the trans and see what is not allowing the pressure to get through. My question is what else could it be? Help
Old Apr 2, 2010 | 06:23 PM
Lost Lake's Avatar
I'll subscribe.
I think the design is faulty and the solenoid is prone to plugging with debris. The 'fix' uses a new solenoid mounted at a different angle. Less prone to gunk I would suspect.
Old Apr 2, 2010 | 06:43 PM
mastertech's Avatar
500 bucks for an hour job. did they really change them, ive seen to many just clean the screens only to work for a bit then go back to the way they were. make them change them again and filters also
Old Apr 2, 2010 | 11:37 PM
painter68's Avatar
don't get ripped off
Hey dale, I just did the same fix and knew nothing about it going in. There are threads on the website that show u how all the way down to torque specs. You're symptoms are definately the solenoid and / or transducer. Did they replace both? sometimes it is one or the other or both. P.s. Once you do this procedure and know how it probably would'nt take an hour. Good luck.
Old Apr 4, 2010 | 07:57 PM
dalewclark's Avatar
yes both were replaced and still have the same problem
zookeeper
Aug 13, 2011 12:08 PM
90firstgen
Apr 25, 2008 07:59 PM
abc4yew
Mar 29, 2008 08:37 AM
06RAM2500
Feb 12, 2008 08:47 PM
ventrian
Mar 16, 2007 10:41 PM
