Starting with out electrical
Old 07-07-2007, 12:14 AM
kellypckp's Avatar
I need alittle insurance, I would to like to start the truck and be able to move it under its own power. Don't have all the electrical done.
Can I just put 12V to the fuel solenoid of the pump and to the starter just to make it run?
Old 07-07-2007, 04:43 AM
BearKiller's Avatar
Call Geico, the lizard people.
YES
Old 07-07-2007, 06:35 AM
The lizard saved me $400 a year!
Old 07-16-2007, 01:26 AM
kellypckp's Avatar
If not the solenoid
What is the other electrical connection of the side of my injection pump. I thought that was my soleniod. Was wrong verify wrong.
Also can you give me a quick run down on how my 91 non-intercooled injection pump works, or a link.
Old 07-16-2007, 12:44 PM
dpuckett's Avatar
the solenoid you are looking for it right above where the lines come out of the pump- has two prongs on it. Run a wire to it, and it will run. If not, you need to dig deeper. The one on the lower left side of the pump is the KSb- cold start advance, and wont allow it to run.
DP
Old 07-16-2007, 04:26 PM
jimlj's Avatar
12 volts to the fuel cutoff and starter and it will run. Nothing else is needed. I am told your ksb moves the timing on cold starts. I know it is not necessary to start the engine as I ran mine for 4 weeks without it. I believe you want to hook it up though for a permanent thing. I just wired my brain box in this past Saturday. I don't know if the ksb is doing anything right now since it is so warm here, but hopefully it will all work as the weather gets colder. Search "brain box" for wiring information that wanna posted in answer to my question on what the wires went to.
Old 07-16-2007, 07:01 PM
That's the KSB solenoid, as Jim said it advances the timing. The engine will run with it disconnected.
Take a look in the sticky at the top of this board, there is a good discussion of VE pump operation in there.
laohu69
12-08-2013 04:14 PM
RED99CTD
04-20-2011 08:08 AM
Thiss
09-28-2010 10:41 AM
Sculptorsam
03-16-2007 05:18 AM
abc4yew
03-15-2007 11:55 PM
Quick Reply: Starting with out electrical
