stacking
Old 01-08-2008, 09:46 AM
sleeperman's Avatar
stacking
What would stack the best with my smarty? A edge ez, a mp8, or a power puck?
Old 01-08-2008, 09:55 AM
DTR 1st Sergeant
soulezoo's Avatar
Power puck is cheapest... MP-8 most flexible and effective. I have no experience with the edge...
If $$$ are a concern I'd go puck, you can get them used very cheaply and they are effective. If $$$ are not a concern get the MP-8.
Old 01-08-2008, 12:53 PM
sleeperman's Avatar
Do you have your boost fooler first or your mp8?
Old 01-08-2008, 04:08 PM
Tuf-4x4's Avatar
Boost fooler?
Old 01-08-2008, 04:18 PM
Cruizer's Avatar
Build your tranny or get a clutch first. The Smarty will give you more than enough power as it is to trash your tranny. After that get a TST, turbo, and maybe injectors.
Old 01-08-2008, 04:30 PM
DTR 1st Sergeant
soulezoo's Avatar
right now it is the puck installed... it goes MAP sensor to powerpuck to boost fooler to harness.
Old 01-08-2008, 08:07 PM
sleeperman's Avatar
i have the smarty on the highest seating all the time and the torque mannagment on monderent and it seemes to be fine even lunching in four wheel drive. I just want it to pull a bit harder on the top end.
Old 01-08-2008, 09:36 PM
desertchecker's Avatar
which program are you running ?
I suggest getting a rail pressure gauge first , this is a nice thing to have so you can have look at what the rail pressure is doing @ wot.
my smarty pulls real hard on the top end 4.3 beta alone with no stack. for street driving and towing the 4.4 beta alone no stack , works very very well & still pulls strong on top end with less power and less coal then 4.3 beta
sleeperman you could benefit more right now from a fuel system & rail gauge, and other needed gauges before adding any pressure boxes, you also will be needing a built transmission very shortly, even with just the smarty on low #s & no stack.
maybe others will chime in soon with more information ......
Old 01-09-2008, 09:53 AM
sleeperman's Avatar
I have a boost, pyro, and a tranny temp. Have been looken at a quadzilla recone for the pressure.I need to buy a turbo cuz my pyro is getting peged just with the smarty but dont have the money yet and just want the mp8 for when i drag race somebody.
Gene007
10-27-2003 03:43 PM
mcevins
08-30-2003 11:09 PM
John_P
24
07-13-2003 08:59 AM
Timinva
11-23-2002 05:44 PM
Quick Reply: stacking
