squeeking noise and nuts
Old Jun 3, 2005 | 09:48 PM
DodgeDog's Avatar
once the truck encounters bumps small bumps i get this squeeking noise coming from the extended cab area on the passanger side. i cannot figure it out and it is driving me nuts. anybody have any ideas short of selling the truck.
Old Jun 3, 2005 | 10:06 PM
phox_mulder's Avatar
Cab mounts would be a good place to start.
phox
Old Jun 3, 2005 | 10:55 PM
torquefan's Avatar
Quad cab rear doors? Get a passenger to lean on the door and see if it goes away. (the noise, not the passenger )
Old Jun 4, 2005 | 12:18 AM
upersleder's Avatar
i had a rock slip in the cab mount once on my truck, took awhile to find.........
Old Jun 4, 2005 | 04:57 AM
DodgeDog's Avatar
some great ideas. i am going to try them today.
Old Jun 4, 2005 | 08:26 AM
Mopar1973man's Avatar
Check your bolts in the bed too... Mine got a strange gunt / squeak on un-even roads...
Old Jun 4, 2005 | 04:00 PM
doodah's Avatar
GOT leather seats? mine make a squeeky noise simaler to what your talkin about!, also the fuel tank might be the culpret!, a fuel tank can make some squeeky sounds rubing on the frame or the bands.
Old Jun 4, 2005 | 04:46 PM
DodgeDog's Avatar
cloth seats, with rear one out. I lubed the fuel tank bands down with a light oil.
Old Jun 4, 2005 | 04:51 PM
TxDiesel007's Avatar
Mine squeak
but its the plastic on the top of the bad that is kinda loose.. have yet to tighten them... thanks for the idea tho!..
Tx
Old Jun 4, 2005 | 06:26 PM
Holiday's Avatar
My quad cab door squeaked also. I finally found that the bottom latch wasn't latching so in effect the front door was holding it shut but it squeaked under certain conditions. Lubed it up and is fine now.
Old Jun 5, 2005 | 09:55 AM
DodgeDog's Avatar
Well I lubed down the door gasket all the hinges and the latches. I will keep you guys posted. Thanks for all the ideas.
Old Jun 5, 2005 | 08:05 PM
DodgeDog's Avatar
well none of the above helped the squeek is still there. anymore ideas guys.
Old Jun 6, 2005 | 02:42 PM
Korney's Avatar
I picked up some new pins and bushings for my front doors last week. If I grabbed the back of my doors and lifted I got a lot of movement at the pins. You have to grind the stock ones out the first time but after that they just bolt in for easy changing after that if you wear them out again. Got them at NAPA for 12 bones and Dodge could only get me complete door hinge.
Old Jun 6, 2005 | 03:13 PM
darrenG's Avatar
Still squeaking, eh? Could be an exhaust hanger, too.
Best way I've learned to find a squeak is follow the sound. Have someone else drive on a road where it squeaks a lot and start crawling around listening. If it will squeak at low speeds and you can't find the sound inside, walk along outside with someone driving and listen (if you had a manual you could just drop it in first and get out ). Might have to find a long stretch of road where it'll squeak, build some momentum and turn the diesel off to hear anything.
lokin4deer
Feb 7, 2006 10:53 PM
Geets
Oct 12, 2005 08:01 PM
BAJA MAN
May 7, 2005 11:31 PM
Goodys1ton
Mar 28, 2005 06:51 AM
