Spuddding noise & water temp???
Old 07-08-2007, 07:24 AM
GaCamper's Avatar
Took a trip over the the 4th and pulled our fifth wheel to the North Georgia Mountains. This was the first long trip we took with the new camper. Camper weighs around 11,000 lbs.
Everthing worked great truck did a good job. Did have two small problems.
On hard up hill pulls I would hear a spudding noise while pulling the fifth wheel. Sounds like air blowing out. Only does it while pulling the fifth wheel on long hard up hill grades. Doesn't do it on level ground or normal highway driving.
Also while pulling the fifth wheel on up hill grades or running on level ground at 70 mph the water temps rises to about 1/2 to 3/4 ways of the stock gauge. Never had it read that hot before. Once I back out of it and run along at 60 or 65 the temp drops back.
Any suggestion on what to check for both problems...Thanks
Old 07-08-2007, 07:28 AM
What turbine housing are you running? Sounds like it could be a turbo surge.
Did you ever hear the fan clutch engage when the engine got hot? If not, reach down between the fan and radiator and rub the front of the clutch. Look at your fingers - if they have oily goo on them it's time for a new fan clutch.
If you heard the clutch kick in: How old is the radiator? If it's original to the truck that is likely the problem.
Old 07-08-2007, 07:36 AM
GaCamper's Avatar
Still running the stock turbo housing. This is the first time I've ever heard the spudding noise...
I'll check the fan clutch, I believe it was working.
I had the same thought about the radiator, it may need a good cleaning. I can only guess it is the original....I've had the truck now for about 5 years and never done anything to the radiator or fan...
Only other thing is I never did get over 15 psi boost during the whole trip...No matter how hard I pushed it...I was thinking more towards the intercooler/hoses my be leaking.
Old 07-08-2007, 07:41 AM
Well you never mentioned THAT...
Old 07-08-2007, 08:26 AM
GaCamper's Avatar
Sorry about that..I was on my first cup of coffee when I posted that...
Old 07-08-2007, 10:36 AM
I would pressure test the intake system before you do anything else. It is likely just a boot with a little hole wore in it.
Old 07-08-2007, 01:33 PM
GaCamper's Avatar
Checked my fan and just what you said. The center of the clutch is greasy feeling. I take it that should be clean...Now to fan a fan clutch!
If that turns out to be the case, where is the best place to get new boots?
Old 07-08-2007, 01:37 PM
I got my boots from stylinmotors.com
Old 07-08-2007, 01:48 PM
GaCamper's Avatar
Thanks found the page. Don't mean to sound like a dummy here. I take it you order the Straight Hose and cut it to the length you needed....Right??
If so what size is needed for the 93 Cummins.
Old 07-08-2007, 01:58 PM
You could do that, but I bought hump hoses. Stock size is 2.5"
Old 07-08-2007, 02:14 PM
GaCamper's Avatar
That was going to be my next question also...My truck has hump hoses on it. Was wonder ing it's better to go back with hump hose or straight hose...
Old 07-08-2007, 02:50 PM
GaCamper's Avatar
My intercooler hoses are 4" inches long...What I'm seeing online are 3" inches long.....Being a inch shorter then the stock hoses, will everything fit back together ok?
Old 07-08-2007, 05:11 PM
Ace
Ace's Avatar
Let me know if you find 4" silicone hoses, hump or otherwise. I've tried and can't. That sttylin' place will make them custom, but the prices, geeez!
Old 07-08-2007, 05:26 PM
GaCamper's Avatar
I've been looking and everything I find is 3" long. Was just wondering why the stock boots are 4" long and all of the replacements boots online are 3" long....Can anybody answer that one??
Old 07-08-2007, 05:58 PM
loch's Avatar
On my friends truck i replaced his and the new ones were 3 inch and seemed work fine. Also when you put em on spray a bit of belt dressing on them before sliding on. It keeps them from blowing off, if you dont have any belt dressing steal the wifes hair spray.
PRO-NRA
02-10-2009 04:59 PM
weldman05
05-21-2007 10:10 AM
jaconst
06-25-2006 10:23 AM
turbox2
02-06-2006 07:44 PM
firesine
11-24-2005 10:58 AM
Quick Reply: Spuddding noise & water temp???
