Speedo ?????
Old Nov 23, 2009 | 11:41 PM
oilburner 5.9's Avatar
Speedo ?????
i have had volt. reg problems lately my alt. was maxing out a battery tester. i think cause of that it knocked out my speedo is there a way to fix it or am i pretty well screwed
thanks in advance for your help
Old Nov 24, 2009 | 09:16 PM
anybody have any ideas, anything would help
Old Nov 24, 2009 | 09:25 PM
comptz's Avatar
i would say on your 90 the spedo is driven mechanicaly. Check the spedo adapter.
Old Nov 24, 2009 | 10:05 PM
I disassembled the cluster and hooked up the speedo to a 12 volt power supply and nothing I tried my fuel gauge and it work fine. Does it have to be hooked up to the sensor on the trani for it to work? I noticed that one of the resistors was a little burnt at the connection on the board don't know if that makes a difference. I also put another sensor on the trani don't know if it was good since it was used.
Old Nov 24, 2009 | 10:08 PM
comptz's Avatar
on my 89 there is a spedo cable running from the transfer case to the back of the guage cluster. It should be mechanical. Did it work before you took the cluster out?
Old Nov 25, 2009 | 07:16 PM
its electrical its a 90 and yes it did work before
Old Nov 25, 2009 | 07:30 PM
comptz's Avatar
ok, I guess i was thinking wrong. I was thinking the electrical didnt come in until 91.5 with the pcm.
Old Nov 25, 2009 | 07:56 PM
Onemoparnut's Avatar
I think anything wih a 100 mph speedo is electrical. Check the connection at the vss on the trans
Old Nov 26, 2009 | 01:15 PM
are there any other variables that I could try along with that so I can do it all at once?
Old Nov 29, 2009 | 09:12 PM
ok I installed a brand new vss today and got bubkiss.the speedo still aint movin. Anybody tell whats up now?
Old Dec 3, 2009 | 06:52 PM
anybody got any ideas about whats going on??????????
I know this isnt a cool thread about swapping engines or transmissions. BUT I STILL NEED HELP THIS IS MY DAILY DRIVER FOR MY WIFE AND 16MONTH OLD DAUGHTER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 3, 2009 | 06:55 PM
I bet the drive is toasted. Take a good look and make sure the hole the VSS shaft fits into is not all rounded out.
Old Dec 3, 2009 | 09:00 PM
Chrisreyn's Avatar
OilBurner... read this and it will give you an idea what yer lookign at adn what to check....
How the Speedometer Drive Works:
https://www.dieseltruckresource.com/d...d.php?t=198123
Old Dec 3, 2009 | 10:22 PM
Thanks Wanna I'll take a look at that this weekend between wrecks and other tows. hey chrisreyn that link did not work is that in the sticky? I know that there is a worm gear in the tranni to control the speedo and the wear out, but is there a way if the actual speedo is bad because i noticed one of the resistors a little burnt on the back, is there a way to fix it?
thanks jeremy
Old Dec 4, 2009 | 03:34 PM
Chrisreyn's Avatar
Yea, thats an article in the stickey, dont know why it didnt work..
As far as the resistor on the curcuit board, i would imagne it could be replaced, but you'd hav eto be much better at electrical than I am.. cant give ya any advise on it..
TJE
Mar 9, 2011 06:48 PM
Paul S.
Feb 20, 2003 05:29 PM
Monty
Feb 9, 2003 05:07 PM
chdiesel
Oct 31, 2002 03:22 PM
