Soft shifting from 1st to 2nd.....
Old 03-02-2010, 11:07 PM
CUM4X4MINS's Avatar
Did a search but couldn't really find what I was looking for and could use some help. My truck just recently just started shifting soft from 1st to 2nd almost like it was slipping from 1st to 2nd. It shifts normal for about the first 15min of driving but then starts doing the above. Any advice/theries would be greatly appricated. Right at about 60k on the clock and fluid and filter change done at 50K.
Michael
Old 03-02-2010, 11:31 PM
Administrator/Jarhead
madhat's Avatar
The bands probably need to be tightened. I think there is a 'how to' here somewhere... I'll look.
Old 03-02-2010, 11:32 PM
madhat's Avatar
Check it out...
https://www.dieseltruckresource.com/...x-t229203.html
Old 03-02-2010, 11:47 PM
CUM4X4MINS's Avatar
Originally Posted by madhat
Thanks for the help madhat...I wasn't sure if it would be the bands or not.
Michael
Old 03-03-2010, 01:00 AM
madhat's Avatar
I'm not either! It's a place to start. Could be the TC, but that should affect you more when applying power, I believe.
Old 03-03-2010, 05:40 PM
CUM4X4MINS's Avatar
Yeah gonna adjust the bands and replace the Governor Pressure Solenoid next week. hopefully that will solve the problem.
Michael
Old 03-03-2010, 07:23 PM
JJPage's Avatar
My Father in law's 03 was doing that at 11k, it was actually shifting from 1st to 3rd, 2nd gear clutches were gone. Bill Kondalay@DTT told me this is not unusual with the factory design. My 2nd gear and overdrive clutches were showing significant wear at 13k, I only had an Edge EZ at that point.
I hope that is not true in your case, Good Luck!
Old 03-03-2010, 10:12 PM
CUM4X4MINS's Avatar
Yeah me too. But I know the truck is still hitting 2nd because it shifts normal for the first 15min of driving and I can tell it is still hitting 2nd but just really soft like its slipping in. After reading some I think it is the bands needing adjustment. Fingers crossed anyway.
Michael
DUNEATIC
09-03-2010 12:40 PM
20073500dodge59
01-08-2008 03:56 AM
fast_enough
10-19-2007 04:00 PM
98 Ram 24V
12-24-2005 10:19 AM
fishin fever
02-16-2005 08:45 PM
Quick Reply: Soft shifting from 1st to 2nd.....
