Smoke Switch/unplug map
Old 08-12-2008, 08:44 PM
babyjoe's Avatar
I was wondering if a smoke switch is the same thing at unplugging the map sensor and if not does it make alot more smoke than just that..??
Old 08-12-2008, 09:50 PM
dieselrob's Avatar
There are the same thing. With the edge comp you just un plug map, and with quad stuff you wire up a switch. Ill it does is foll the ecm boost reading and makes it dump more fuel off idle and make smoke, no extra power.
Old 08-12-2008, 10:15 PM
babyjoe's Avatar
Thats what I figured, I have my map unplugged to get a little more smoke at will..Thanks for your help.
Jordan5687
17
03-26-2007 09:59 AM
Jordan5687
03-11-2007 11:00 PM
Dodgezilla
12-12-2005 10:28 AM
Pull U 2
09-13-2005 02:37 PM
humin cummins
04-20-2003 08:28 AM
Quick Reply: Smoke Switch/unplug map
