Unplug MAP sensor.?
Old Mar 24, 2007 | 12:45 PM
Jordan5687's Avatar
Question Unplug MAP sensor.?
What is the result of unplugging the MAP sensor? Will it cause anything negative when hauling heavy loads? Or daily driving? Thanks!
Old Mar 24, 2007 | 01:08 PM
Jordan5687's Avatar
Anyone know about this?
Old Mar 24, 2007 | 01:09 PM
oaborbag's Avatar
It confuses the computer thinking your at full boost so it increases fuel, giving you more low end, high end is the same, but you "must" have a timing chip such as a edge comp hooked up or you will have just about zero power, I have it done on mine, and I love the difference on the low end, and it smokes more, if thats important
Old Mar 24, 2007 | 01:12 PM
scottsjeeprolet's Avatar
I have mine unplugged on mine but i have heard that it doesn't play too well with the Juice. Try it and see. Make sure you leave it plugged into the Juice and only unplug it from the block.
Old Mar 24, 2007 | 01:15 PM
Jordan5687's Avatar
What about hauling with it unplugged? Will that be detramental in any way? I have the Juice hooked up to everything right now, and the wire is tapped. I'll have to try it sometime, that's great it helps the low end on take off.
Old Mar 24, 2007 | 01:21 PM
ib516's Avatar
Doesn't unplugging the MAP turn on the engine light?
Old Mar 24, 2007 | 01:23 PM
You'll be fine with your EZ. Try it you'll like the off the line power it gives you along with the smoke.
I haven't had any problems towing with it unplugged.
Old Mar 24, 2007 | 01:24 PM
oaborbag's Avatar
been running mine like that for 4 months, no check engine light, but I've read that it acts different with the comp and the juice, but you should just be able to unplug the map plug from the block only, leave the bypass on the juice wire. I think if you research "map sensor" you might be able to find some info on it while you wait for replies.
Old Mar 24, 2007 | 01:26 PM
Jordan5687's Avatar
Will do, thanks for the info on this
Old Mar 24, 2007 | 02:37 PM
ohiostate24's Avatar
How much smoke do you get with nothing but the EZ and the sensor unplugged?
Old Mar 24, 2007 | 07:56 PM
Enough to put a smile on your face.
the off the line power will really make you smile.
Old Mar 24, 2007 | 08:11 PM
What made you get rid of the EZ and go for the Comp, if you dont mind me asking?
Old Mar 24, 2007 | 08:25 PM
mvanhelden's Avatar
I have mine unpluged with a comp box, the check engine light comes on but after a couple key on key off cycles it goes away, it gives real quik throttle response!
Old Mar 25, 2007 | 07:28 AM
Well the MO POWER bug bit me, so i got the Comp.
Old Mar 25, 2007 | 08:03 PM
jlebrun's Avatar
just unplugged my map sensor today, and im loving the smoke
