Smarty ?
Smarty ?
I was thinkin about gettin a smarty, i was windering would i notice a big power gain with the mods i already have, check my sig. And if so how would i run it with the edge?
IMO you will outgrow that hx40 quick if you ever go to bigger injectors or much anything else. I've got the HTT 62/14 with about the same setup as you and I love it.
Hx40 is now considered to be old school and they're known for snapping shafts when used in a performance application, but it'll get the job done. A plain jane s300, hx40, or a 35/40 hybrid is all you're going to find for less than a grand, unless you wanted to run something way to big *insert evil smirk here*
A "little" bottom end is misleading.
No power on a dyno is simply untrue. A smarty will demonstrate power on a dyno, if the dyno can generate any load at all...
JH
He's running a tapped Juice, so I'd tend to agree with Blackdiesel. You can only get so much out of the ECM, and the Juice is already doing it.
Registered
Not a smarty hater, at all. Of all the mods I had on my truck over the years, (edge comp, tst pm3 comp, jammer 4's, mach 6's, sps62, snow stage 2 W/M, and I'm sure I'm missing something) The smarty is all that I'm running now. He just needs more air. Rather than spending $650 on more low end smoke and higher egt's with no more net gain HP. It would shave around 2th's off your 1/4 mile time, if you play with it and find the right setting (even #'s only with that edge) JMO
stock03
34
04-21-2011 07:40 AM
RyeThomas
40
04-20-2007 10:12 PM
CTD_Neil
02-23-2006 09:27 PM
