Smarty question?
Old 01-04-2008, 03:59 PM
Ramtuff06's Avatar
Smarty question?
Is is safe to run the smarty with the aftermarket turbo/injector sw on stock turbo/injectors? if so what are the affects if used.
Justin
Old 01-04-2008, 04:00 PM
Pinksa's Avatar
from what i gather, less timing rattle, and you will get boost fooling..
Old 01-04-2008, 04:13 PM
Ramtuff06's Avatar
will the aftermarket injector sw hurt my stock injectors or will it be fine as long as I don't "get on it"
Old 01-04-2008, 04:29 PM
BBarnett's Avatar
your truck will be fine.The after market injector, reduces timing and the after market turbo disables your electronic wastegate....
Drive as you normally do....
skydiver41
03-23-2012 08:51 AM
stock03
34
04-21-2011 07:40 AM
jmccart
11-22-2007 07:43 PM
Mike Holmen
05-21-2007 10:21 PM
bnold
39
06-04-2006 08:21 AM
Quick Reply: Smarty question?
