Smarty question?
Old Jan 4, 2008 | 03:59 PM
Ramtuff06's Avatar
Smarty question?
Is is safe to run the smarty with the aftermarket turbo/injector sw on stock turbo/injectors? if so what are the affects if used.
Thanks
Justin
Old Jan 4, 2008 | 04:00 PM
Pinksa's Avatar
from what i gather, less timing rattle, and you will get boost fooling..
Old Jan 4, 2008 | 04:13 PM
Ramtuff06's Avatar
will the aftermarket injector sw hurt my stock injectors or will it be fine as long as I don't "get on it"
Old Jan 4, 2008 | 04:29 PM
BBarnett's Avatar
your truck will be fine.The after market injector, reduces timing and the after market turbo disables your electronic wastegate....
Drive as you normally do....
skydiver41
Mar 23, 2012 08:51 AM
stock03
34
Apr 21, 2011 07:40 AM
jmccart
Nov 22, 2007 07:43 PM
Mike Holmen
May 21, 2007 10:21 PM
bnold
39
Jun 4, 2006 08:21 AM
