Smarty JR ?'s
Old 09-03-2009, 08:57 AM
lucey's Avatar
Smarty JR ?'s
I found a decent deal on a Smarty JR which has been upgraded to POD here in Canada. Do i need anything else to compliment it right away ? I plan on a CAI most likely a S&B and a Glacier 392 kit if i can find one, LOL. I have gauges already. Thanks
Old 09-03-2009, 09:33 AM
055055.9's Avatar
No it is made for a stock truck. If it is used be sure it is not VIN locked.
Old 09-03-2009, 10:15 AM
lucey's Avatar
How do i tell ?
Old 09-03-2009, 11:21 PM
lucey's Avatar
I'm not quite sure how the VIN locking thing works. I assume if he has it setup for say tune #1 it is locked. If it reverts back to stock is it still VIN locked ? Need a quick answer ! Thanks
Old 09-04-2009, 12:05 AM
turbochabot1's Avatar
The screen on your Smarty should read [Present SW: Stock] after you have plugged it in and hit the up arrow for [ECM Update] and then the up arrow for [Connect Truck]. If this is the case you should be good to go. If you get the error message VIN# Locked then the unit you picked up has not been restored to stock on the previous owners vehicle. Good luck.
Old 09-04-2009, 08:33 AM
lucey's Avatar
I talked to the guy and yes it will be put back to stock. So all should be good. Thanks
stock03
34
04-21-2011 07:40 AM
RyeThomas
40
04-20-2007 10:12 PM
BigBlue
11-22-2006 02:46 PM
bnold
39
06-04-2006 08:21 AM
CTD_Neil
02-23-2006 09:27 PM
Quick Reply: Smarty JR ?'s
