smarty jr questions
Old Jun 15, 2010 | 12:20 PM
isb07's Avatar
smarty jr questions
hey all i just bought a smarty jr for my 07 5.9. i have been reading up on this jr for a while now and i decided to pull the trigger. my question is when towing with the jr, whats the max egts i want to see? since the jr advances timing, the cylinder temps will be higher and i will see lower egts on my pyro. stock i can hit 1450 with a load on so im assuming 1200 is the max egt with the jr with advance timing, or should i run stock timing while towing. i dont wont to go above sw2 while towing because i like my transmission, well kinda
Old Jun 16, 2010 | 09:07 AM
AH64ID's Avatar
You want to run Smarty timing when towing, I run TM2 all the time (TM3 is too hot, and TM4 is too much soot in the oil)..
I keep 1300* as my limit, with 1350* for short bursts.. But honestly I am hard pressed to even hit 1200* under normal towing.
Old Jun 16, 2010 | 11:21 PM
quadman20's Avatar
Me I'm seeing 1100-1200 on my pulls here in AZ 6% grades 90-105 outside temp. pulling my 32' 5th wheel. My Jr is on sw1 tm4 tq4. TM2 is less smoey though. I couldn't say on the soot part as my oil is black as coal since day one and oil reports are normal.
Old Jun 17, 2010 | 08:43 AM
isb07's Avatar
well fed ex dropped it off this morning and i open it up and its the s06 full version, so someone sent me the big one when i paid for the jr. not sure if im going to like it or not. i dont think i can have all this power at my fingertips.
Old Jun 17, 2010 | 10:45 AM
isb07's Avatar
well i tried it out and i dont really like it. i tried sw1 first and my egts were around 1200 when i backed out of the throttle empty, then i loaded sw2 with stock timing and smoke was a little much but cleared up quick but my egts were 1300 empty. i wanted a good towing tune with low egts but this is a little much for my stock truck. i loaded the stock programing back in, i like the power i just dont like backing off the throttle. im gonna try to unload it and buy the jr.
Old Jun 17, 2010 | 11:02 AM
Wicked500R's Avatar
nevermind...don't think it'll work on an 03'
Old Jun 17, 2010 | 12:41 PM
isb07's Avatar
it says 03-09 on the plastic case but im not sure that makes sense. i thought there were 2 versions one for the 5.9 and one for the 6.7
Old Jun 18, 2010 | 09:57 AM
AH64ID's Avatar
Dont think what will work?
Old Jun 18, 2010 | 10:45 AM
Wicked500R's Avatar
I thought it was a different box for 06' and up. If it's good to go for an 03' , Pm me. I'd be interested in purchasing.
Old Jun 18, 2010 | 01:19 PM
AH64ID's Avatar
Jr works 03-07.
stock03
34
Apr 21, 2011 07:40 AM
Sam Turner2
27
Dec 24, 2008 09:52 PM
D.Wiggs
31
Aug 30, 2007 02:48 PM
bnold
39
Jun 4, 2006 08:21 AM
CTD_Neil
Feb 23, 2006 09:27 PM
