Slide-in Camper Stands
Depends if it is short term or long term! If I am just unloading for a few days to use the truck, then I set it down low on 4 axle stands. When I am storing it for a long period, I use a box that I built out of a couple sheets of 3/4" fir ply and some 2*4s. Box is 2' high, so again the camper sits quite low. In both cases I still leave the jacks down with "some" load on them, to act as outriggers.
Torklift has an interesting option: http://torklift.com/camperpictures.htm
Doug
Doug
I crank my Lance 8.5' down onto a dolly I made with 2x8 treated lumber and heavy duty casters. I roll it beside the garage where the truck can't go (concrete). Then I crank up a bit on the corner jacks to take the load off of the dolly. No problem to leave it on the corner jacks if you have it down low.
I set my camper on wood sawhorses also. I also set the camper jacks down but not loaded. It made it thru our earthquake 6.0?? or so a couple years ago and still holdin. I used 2x6 lumber. The camper also stays up at bed level so all I have to do is jack it a few pumps and back under it.
AK Les
0
Jul 6, 2004 02:51 PM
RamThatStroker
Mar 10, 2003 02:21 PM
