Silver Bullet waste gate adjustment
Old Nov 8, 2006 | 07:22 PM
LethalInjection's Avatar
How do you adjust the waste gate on the silver bullet? I dont have head studs yet and figured its got to be easier to do before it goes on the truck. Or for those of you running them what psi were they putting out when you install?
Old Nov 8, 2006 | 07:24 PM
Ok answered my own question on how to adjust it. But still would like to know what you were seeing when first put on truck. Also which way to turn for more of less..
Old Nov 8, 2006 | 08:25 PM
Billy Ram's Avatar
Use a regulator with a good gauge and take the cover off the waste gate housing. Set the regulator on the presure you want and adjust the actuator to where it will just loosen the waste gates with a little more pressure.
Old Nov 8, 2006 | 08:27 PM
Charlie8301's Avatar
II sets most everything @ 45psi
Randy
Old Nov 8, 2006 | 08:29 PM
LI, just read your sig, that truck's gettin real mean. When did you get the TST.
Old Nov 8, 2006 | 08:31 PM
Thanks guys... I am going to try and attemp this myself over the weekend. Im sure its going to be a ...... trying to hold it and bolt it. But thats life.
Old Nov 8, 2006 | 08:32 PM
Just ordered it with the turbo.
Old Nov 8, 2006 | 08:40 PM
It's not that bad, but an extra set of hands does help
Old Nov 8, 2006 | 09:01 PM
RamWheelsBy4's Avatar
My II SPS66 came set to 50psi, have since had it upped to 55psi.
Old Nov 8, 2006 | 09:11 PM
Are you running studs?
Old Nov 8, 2006 | 10:02 PM
I am now, but I ran for about a year without them. I would see 55psi every run at the track. The Smarty has added a lot of fueling ability past the 3300rpm level and probably serious cylinder pressure possibilities so I did have the studs installed. That was after I blew out the rear freeze plug and thought at first it was the head gasket .
texhand
Feb 9, 2008 07:56 AM
Rollincoal
Apr 14, 2006 11:22 AM
rockwithjason
Jun 28, 2005 12:47 PM
bv12
Oct 10, 2003 09:27 PM
