Signs of bad injector?
Old Sep 4, 2007 | 12:05 PM
CTDowerTN's Avatar
what are the signs of a bad injectors? my MPG has decreased here latley, and seems like the oil level is alittle higher then it should be. or i could just be making myself imagine things...lol
Old Sep 4, 2007 | 12:51 PM
Texasimport's Avatar
I am sure others will add on but.
rough idle when you start it up.
a bit of white smoke at start too.
These would indicate slight leak so when you fiorst start you have some extra fuel in a cylinder and get the smoke and rough idle.
good luck.
Old Sep 4, 2007 | 01:02 PM
FOXY005's Avatar
Long Crank / Hard Start
Injector bleeds down and Rail can't build enough pressure to fire injectors.
RobG
57
Mar 6, 2018 06:56 PM
mstep3
Jan 22, 2011 10:24 PM
kycurs
Jul 22, 2006 07:13 PM
MJDiesel
Nov 29, 2005 04:56 PM
TE-44
19
Oct 29, 2003 04:23 PM
