Shudder through first gear
Old 04-15-2007, 12:55 AM
megamac's Avatar
I have searched this and other forums without luck. SO the question; I have a 99 auto. As I accelerate from a stop, I get a shutter or vibration that seems to start at the front of the truck and move its way to the rear and then gos away until I start again from a stop.
I replaced the TC and the tranny (unrelated failure) and the shuter has not changed. I also had the rear Diff serviced thinking that some service guy may have used the wrong gear oil in the limit slip. No help.
The U-joints visually appear OK, no slop, but maybe under a load???
Any suggestions of where to look would be appreciated.
Old 04-18-2007, 07:10 PM
megamac's Avatar
I guess no one has had this problem before..
Old 04-18-2007, 07:19 PM
scottsjeeprolet's Avatar
Have you adjusted the bands on the tranny yet?
Old 04-24-2007, 05:47 PM
megamac's Avatar
The Tranny is new. The shudder has there before the new tranny as well. The truck is lifted, could it be the angle of the drive shaft to the rear diff?
Old 04-24-2007, 07:59 PM
starkey's Avatar
You check your carrier bearing?? Mine, although a 6speed, had a shudder through 1st and 2nd.. replaced the carrier bearing and she's all smooth now
Old 04-26-2007, 05:39 PM
megamac's Avatar
I have not checked the Carrier Bearing. I will do that this weekend. Thanks!
Ramcam
08-25-2013 01:40 AM
ladle_slag
02-24-2009 08:06 PM
Rafter B
04-13-2008 09:40 AM
falcondan9570
08-19-2004 06:16 PM
kertoncol
10-12-2003 03:04 PM
Quick Reply: Shudder through first gear
