"Shudder In 1st or 2nd Gear"
Old Aug 9, 2004 | 07:57 AM
falcondan9570's Avatar
Any of you who have the manual tranny get a "shudder" when using 1st or 2nd Gear?.. Does not do it in all other gears... I have a 'feeling" it is the 'governor' that Dodge uses so one does not have to use the Clutch to get underway .... Also, another complaint is that when taking off from a stop, it seems that it is "painfully" slow to get the truck up to 20 to 25 mph so as to get the truck moving into traffic.. Dan
Old Aug 9, 2004 | 08:51 AM
bulabula's Avatar
Dan, No shudder here. The shudder has been mentioned before by other folks here. I think most (but not all) of those guys have long beds. Usually when pulling a load.
Why do you think the zero throttle feature is the cause?
It might help to fill out your sig block so people know what kind of truck you've got; but mine has no problem moving into traffic - unloaded or not.
Old Aug 9, 2004 | 09:54 PM
AaronT's Avatar
I have a slight shudder in 2nd gear after take off with clutch fully released. I noticed this on my pre delivery inspection and brought it to dealers attention. "Don't know but monitor it and see if it gets worse".
What I think mine is that the idle speed on the 325 is low and the pilot injection is a little off and until the engine comes up about 100 or 200 rpm there is some timing issues causing shudder. I also think the 325 is using a bunch of fuel at idle because of this. Just my opinion, and monitoring it for now.
Old Aug 14, 2004 | 05:40 PM
IA_James's Avatar
Mine does it too, just off idle in 2nd gear, never noticed it in 1st. Can't really come up with a reason for it in my little pea brain, but don't spend alot of time thinkin on it either. Not like when you shut her down or anything, so I don't worry.
Old Aug 19, 2004 | 06:05 AM
Rob_OBX's Avatar
mine does it. 1st and 2nd gear, no load, loaded, doesn't matter. sometimes worse than others. dealer said they don't think they could get rid of it.
a buddy of mine that is a DC master tech said there is a TSB for the shuddering. it puts a spacer above the...(can't remember the name, big rubber thing that hold the center of the driveshaft in place) to move the driveshaft down a little to change the angle of the shaft at the pinion.
Old Aug 19, 2004 | 06:16 PM
J&L's Avatar
J&L
Dan
mine shuddered in 1st and 2nd only when loaded. I added Timbrens to keep rear from sagging and the shudder stopped. .......JIM
Rafter B
Apr 13, 2008 09:40 AM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
texasredrider
21
Jul 13, 2006 09:10 AM
1st gen Hobie
Nov 10, 2004 02:03 AM
kertoncol
Oct 12, 2003 03:04 PM
