should I recalibrate for 285's ??
Old 04-10-2007, 03:39 PM
expressfish's Avatar
I dont think the speedo is maybe 2mph off.......should I have it recalibrated ??
Old 04-10-2007, 04:42 PM
greasemonki's Avatar
I have a 2nd gen...but I went up to 285s, and my speedo is actually more accurate now, then with the 265s! go figure
Old 04-10-2007, 06:48 PM
Argo's Avatar
I never did mine, just be aware of it when in a speed trap area. I figure that I just rack up that many fewer miles on the odometer...... Also, it is off more than you think, probably about 5 mph when doing 70.
Old 04-10-2007, 07:32 PM
973604x4's Avatar
when my 295's were new, it was off 5mph at 70
Old 04-10-2007, 08:22 PM
RamWheelsBy4's Avatar
I would, had mine done for the 315s and then for the 285s. I like the OD and trip to be correct. Not sure if it really affects any shift points, but just feel better knowing that the computer is seeing the right speed/rpms. Just my .02.
Old 04-10-2007, 10:16 PM
boostjunkie1's Avatar
I have GPS'd my 33-12.5-17 ProComps and they are Exact to what the speedo says! Onlt thing that I can think of is that the Speed Gauge was off from the factory!! These are roughly the exact same size as 285's!! Just GPS the truck with teh new tires and see what it says! JB
Old 04-11-2007, 09:22 AM
yeah, I gps'ed it with 295 nittos and it was 4-5 mph off. They were a 33in tire. Took the tires back and swapped out for 285's , so it shouldent be much off. Was thinking more along the line of shift points, but our trannys are crazy and have their own minds anyway
Old 04-11-2007, 11:59 AM
BMH95's Avatar
My shift points changed when I had it recalibrated for 285's.
Old 04-11-2007, 01:04 PM
for better or worse ??
Old 04-11-2007, 02:49 PM
B-MAN's Avatar
X2, speedo is bang on with the GPS 305/65-17 (33x12.5-17) PROCOMP X-AT's,...when I had the 285 BFG AT's I was 2% over...
Old 04-11-2007, 02:51 PM
omaharam's Avatar
Why not have it accurate?
Remember guys, it's not a set value difference. It's a percentage. If you're 5% off at 30mph that's only 1.5mph, but at 70mph, it's 3.5mph.
Old 04-12-2007, 08:30 AM
BMH95's Avatar
The shift points are higher, so it depends on what I'm doing at the time. TC lock is now at 52 instead of 49. It really didn't changed things much, but it seems like the computer now compensates for a little planned power loss with letting the motor get a hair further up in the power band.
Old 04-12-2007, 08:55 AM
Fisherguy's Avatar
... up to you isn't it?
Me? I had the dealer do redo it when I had it in for a recall, I like things to be accurate.
Old 04-12-2007, 10:06 AM
RedRacer44's Avatar
Anyone know how much it costs to have the dealer re-calibrate your speedo if you take it in? I've tested mine by driving next to 3 different vehicles at 65-80 MPH and I was spot on but I'd like my odometer/trip to read right...
Thanks for the input!
EPCO
06-09-2009 02:22 PM
taken5875
11-17-2008 10:48 PM
lawnman757
01-10-2008 12:45 PM
whitetrash66
07-11-2007 02:17 PM
wood_n_soldier
01-16-2007 12:52 PM
Quick Reply: should I recalibrate for 285's ??
