Seatbelt light comes, need help
Old 11-24-2008, 07:18 PM
smokeum99ta's Avatar
Recently my seatbelt light comes on even when I have the seatbelt on. It randomly comes on and off while i'll driving. I checked the connection under the seat but it was not loose or dirty inside. All the bolts holding down the seats are tight so I don't think its a bad ground or something similar. Any ideas???? Thanks Ken
Old 11-24-2008, 08:36 PM
dozer12216's Avatar
Corroded switch in buckle, damaged wiring are most likely. Can you wiggle a fastened buckle and get it to go on or off?
Old 11-25-2008, 10:22 AM
matthopp's Avatar
mine does the same thing...inside the buckle. Lately it has been working, but I am sure it will start blinking soon.
Old 11-26-2008, 03:40 PM
Wiggling it does help. It just does what it whats to.
Old 11-26-2008, 08:48 PM
srv8800's Avatar
does the belt lock up? if so, you have a fuse out. that's what fixed mine.
Old 11-27-2008, 11:44 AM
Jakebud's Avatar
Cure it forever!
Get behind your drivers seat, and locate the wire harness that goes towards the buckle. You might have to remove a bit of wrap covering said harness. Inside the harness there are two wires. Cut those, wire nut them together, tape that up, and you're done. Your nuisance light will never come on again.
SPIKE
Old 11-28-2008, 08:18 AM
No the belt works fine.
Old 11-28-2008, 08:19 AM
SPIKE
I just might do that.
Old 12-02-2008, 11:23 AM
SIXSLUG's Avatar
Just unplug the switch connector under the middle seat. You guys and wire chopping crack me up!
Mine was doing this too and a few shots of electrical parts cleaner in the buckle cleared it up .....for about a month and it started again. $104.00 gets you a new female end for the driver's side belt from the dealer.
Some feel the light is tied in with the airbag and should be repaired, not unhooked and ignored. I haven't had a concrete answer from anyone yet on this matter so good luck if you choose to disconnect it!
Kurt
hconstantino
05-03-2010 12:15 PM
DiEseLjunKy
01-30-2007 10:53 AM
tenmile
07-27-2006 10:42 AM
Cummnzpowr
01-26-2004 08:35 PM
Hummin Cummins
15
03-06-2003 06:45 AM
Quick Reply: Seatbelt light comes, need help
