RV 275's Question
Old 06-08-2005, 01:11 PM
HappyGA's Avatar
RV 275's Question
I can get a set of used Rv 275 injectors for $200. I don't kmnow the guy from adam, and was wondering if I should have him get them pop tested to make sure they are pretty much equal.
how hard is it to install these injectors on the 2001 dodges? Is it a do it yourself project. Or should I just let the local diesel shop do it, while they check the lash? Truck hass 133,000 on it now, and has never had a tune up, so I thought I would get the lash adjustment done, that is if the valve cover has to come off to put the injectors in.
Old 06-08-2005, 01:14 PM
Tiny's Avatar
For a little more money I would buy new. I got mine for less than $300.
Old 06-08-2005, 01:35 PM
Mike D's Avatar
Injector install is pretty straight forward, valve cover has to come off. Don't know about checking the valves, but couldn't be that hard.
http://www.lib.uaa.alaska.edu/~tibor...structions.pdf
Old 06-08-2005, 02:34 PM
HOHN's Avatar
If you go with 275s, buy new. Do it yourself and save the money. Injector install is NOT hard, and there are no special tools, aside from maybe a 19mm stubby wrench.
PM if you need help
Old 06-08-2005, 10:53 PM
BigBlue's Avatar
Buy new ones. They are to cheap to not buy new. I installed mine in about 2 hours and that's including lunch.
12valve
02-02-2009 06:20 PM
ScreaminEagle
25
11-05-2007 08:15 AM
GTSDave
07-08-2005 09:06 AM
bdog
31
01-10-2003 08:08 AM
drecu
11-08-2002 01:41 PM
Quick Reply: RV 275's Question
