RV 275's Question
RV 275's Question
I can get a set of used Rv 275 injectors for $200. I don't kmnow the guy from adam, and was wondering if I should have him get them pop tested to make sure they are pretty much equal.
how hard is it to install these injectors on the 2001 dodges? Is it a do it yourself project. Or should I just let the local diesel shop do it, while they check the lash? Truck hass 133,000 on it now, and has never had a tune up, so I thought I would get the lash adjustment done, that is if the valve cover has to come off to put the injectors in.
Injector install is pretty straight forward, valve cover has to come off. Don't know about checking the valves, but couldn't be that hard.
http://www.lib.uaa.alaska.edu/~tibor...structions.pdf
If you go with 275s, buy new. Do it yourself and save the money. Injector install is NOT hard, and there are no special tools, aside from maybe a 19mm stubby wrench.
PM if you need help
PM if you need help
12valve
Feb 2, 2009 06:20 PM
ScreaminEagle
25
Nov 5, 2007 08:15 AM
GTSDave
Jul 8, 2005 09:06 AM
