Runs then Dies
Old Dec 5, 2007 | 08:40 AM
stubby1915's Avatar
Runs then Dies
My truck runs well for about 5 miles then it dies. I have replaced the fuel filter after the first time it died, the lift pump is only about 1 year old, I have checked the shut off solenoid on the IP but only electrically, do these things work intermittantly when they are getting worn out? I have had a problem there before but i just replaced the stock connector on the wiring.
The previous owner put a second fuel filter on is this a good thing or not i have been reading about the longer fuel filters some of you use and was wondering which set up is better
Old Dec 5, 2007 | 10:32 AM
G1625S's Avatar
Does it just quit like when you turn the key off, or does it stumble and die? If it just quits, try hotwiring the solenoid to the + battery terminal. If that's a fix, perhaps the ignition switch key-on source has a short of some sort. If it dies off slowly, like it's running out of fuel, I'd have a close look at the filters and connections. Maybe you're a bit gelled up. Hope this helps.
BTW--Welcome to DTR--Glad to have you along
Old Dec 5, 2007 | 11:57 AM
stubby1915's Avatar
changed the stock electical connectors on the IP and seems to be workin now, thanks for the Help and im glad to be here
Old Dec 5, 2007 | 06:42 PM
G1625S's Avatar
Gotta love the simple fix--keep on truckin'!
benroberts3605
29
Dec 22, 2011 05:45 PM
N8theGr8
Feb 13, 2008 12:36 PM
Luckyrogue
Jan 16, 2008 11:54 AM
xfeastonarsex
Feb 5, 2007 05:35 PM
N777TC
Jan 25, 2004 11:47 PM
