Runs rough on first start up
Old Feb 5, 2007 | 09:42 PM
04 dodge diesel's Avatar
04.5 has been running rough on first start up in the mornings ,sets inside overnite {temp.40's to 50's inside} . After work on cold days same in the 20's.Last 1 min. or less ,sounds like a flooding gas engine and smoking more than usaual .I noticed it's taking more cranking time than it use to also . Have edge with att. ,else is stock.What 's going on?: (
Old Feb 6, 2007 | 01:10 PM
BigDave12768's Avatar
Do you run any addatives? That would be my first easy fix to try. Also when was the last time you did the fuel filter? 2 easy fixes to try that are under $20. One other thing white smoke or black smoke. And do you push your Edge back to stock on start up?
Old Feb 6, 2007 | 09:28 PM
I use amsoil fuel additive. I thought of turning off the edge ,tried it this morn. it was better but temp. was warmer today 25 .Temps were in the low teens. Fuel filter is not due yet. May try it tho. Is the edge suppose to be off during cold start up?
Old Feb 6, 2007 | 09:29 PM
GRI's Avatar
GRI
do you have a ROKK tech sensor?
Old Feb 6, 2007 | 09:31 PM
no,I don't
soilsample
Dec 7, 2010 08:05 AM
RLS
Nov 7, 2007 05:03 PM
Ripper406
Oct 8, 2007 12:16 AM
wilderness
Sep 17, 2006 08:23 PM
wcso873
Feb 3, 2006 03:11 PM
