Remote fuel filter mount on frame rail
Old Jun 30, 2006 | 11:00 AM
bgilbert's Avatar
I'm looking for a remote fuel filter mount for my truck. I'll be using 1/2" ID fuel line. I've dug up a couple mounts in some old threads. One using a Cat filter, others using equivalents - cheaper. The filter water separator I probly will use is Fleetguard FS1000. The two mount part numbers I came up with are Fleetguard 3930618S http://www.fleetguard.com/fleet/en/...talog_popup.jsp and Donaldson P174769 https://dynamic.donaldson.com/webc/....html?item=1860. Both show 1/2" inlet and outlet. The equivalent in the Baldwin number FB1311 http://catalog.baldwinfilter.com/catalog.html showed the same mount, but it had 7/8" inlet and outlets.
My question concerning the inlet and outlet size, when it says 1/2" inlet, does that mean it's for 1/2" ID fuel line or 1/2" OD fuel line? I don't want a restriction. Thanks for any help on this.
Old Jun 30, 2006 | 01:31 PM
Rods's Avatar
http://www.perma-cool.com/Catalog/Cat_page26.html
Thats what i use , 1/2 in / out
Old Jun 30, 2006 | 01:35 PM
bgilbert's Avatar
Originally Posted by Rods
I've seen that one. I haven't seen any specs on the filter size. Is the filter nipple 1"-14 like the ones listed above, ie will a bigger filter such as the FS1000 thread onto it?
Old Jun 30, 2006 | 01:42 PM
JD730's Avatar
When they say 1/2" it usually means 1/2" NPT (national pipe thread) which will have an OD of around 3/4"
Old Jun 30, 2006 | 01:45 PM
bgilbert's Avatar
Thanks alot Mike! You are the man, I don't care what Underpsi says about ya .
Old Jun 30, 2006 | 05:13 PM
Rods's Avatar
yeah 1/2 npt , im not sure on the thread size of the filter , its a 5 micron filter pretty decent ,
Old Jun 30, 2006 | 10:03 PM
Silverjay's Avatar
Are you guys running the filter pre or post lift pump?
Old Jul 1, 2006 | 09:27 AM
Rods's Avatar
i run post , i run a holly volumax 160 pump that has a 40 micron filter , i trashed the factory lift and filter assembly
i run 1/2 lines all the way to the vp
Old Jul 2, 2006 | 10:58 AM
mcctho21's Avatar
NAPA Part Number 4770 is a universal filter base that the fleetgaurd fs1000 fits perfectly. Just picked it up yesterday for 35 bucks. Pricey but fairly nice. 1/2" NPT.
Sittingbull2
Dec 15, 2011 04:45 PM
J OOPS
Jun 1, 2009 04:34 PM
ptgarcia
Sep 12, 2006 06:04 PM
eastmentCTD600
Jan 13, 2005 10:35 PM
phloop
Dec 28, 2004 08:36 PM
