rattle/drivers side floor area
Old 11-28-2006, 06:09 PM
TIMMY22's Avatar
I have a rattle under the drivers side floor area. I looked underneath for a culprit but couldn't find anything. I did a few searches and came up with shock bolts and steering shaft bushing. I checked the steering shaft bushing today and it feels real tight. The shock bolts sound more like it because I just replaced the shocks about 2 weeks ago. I was sure to put the rubber gromets in on the upper washers.
How many foot pounds on those lower bolts?
someone else had a steering box working it's way loose from the frame? is this common?
Old 11-28-2006, 06:17 PM
phox_mulder's Avatar
I'd say either your lower shock bolts, or your control arms might be a tad loose on that side.
phox
Old 11-28-2006, 07:16 PM
hamilton71801's Avatar
How many ft/lbs? Get the biggest, baddest impact you can find and give it hell. That's how many ft/lbs it takes.
Old 11-29-2006, 04:48 PM
b.lee's Avatar
i used a 1/2 ratchet w/ a huge pipe to get the lower front shock bolts tight enough... i dont think anyone is going to have a good enough impact for those.
Old 11-30-2006, 08:13 PM
cumminspower79's Avatar
In another thread similar to this, someone had a loose wheelwell liner. The stock plastic rivets get worn out, I had this same problem with a rattle as well in that spot.
Old 12-01-2006, 12:48 PM
TIMMY22's Avatar
update
Ok, as suggested I tightend the dickens out of the lower shock bolts and did find a loose fender well that I put a new screw in. took it up the road and it's gone!
Thanks again boys!
joem
04-10-2012 12:14 AM
tpollon2
01-12-2011 02:36 PM
blackfordd
07-13-2010 12:16 PM
DNRCustoms
06-16-2009 09:38 AM
kawi600
06-28-2006 07:42 PM
Quick Reply: rattle/drivers side floor area
