Questions about my truck "electrical"
Old 12-14-2008, 02:39 PM
omlambu's Avatar
I bought this truck in October and Had my first problem with it last week. My headlight went out. While diagnosing this problem I found that a lot of my fuses were over rated in the fuse box. Two of them I don't think I need can you guys help?
Fuse E i show to be for Quad lamps-how do I know if I have this?
Fuse F is basically all the park/running lamps correct?
Fuse G is security and/or Daytime Running Lamps, Do I have either of these?
Fuse I Tranny control relay. I know I have it does it do anything else?
So I don't think i need Fuse E or G what do you guys think?
Also over rated in the cab fuse box were
Fuse 6 Wipers?
Fuse 12 all internal cab lights?
I know if the fuses start to blow I have a intermittent short I need to find, but I'll get to that when it happens
By the way, I got the headlight going. and already put in the correct fuses. Let me know if you need any more info
2002 Dodge Ram 3500 Laramie SLT
Old 12-14-2008, 05:05 PM
cLAYH's Avatar
You only need the fuse in for the quad lamps if you have the "sport" package with the Quad lights(4 headlights instead of two).
Old 12-14-2008, 06:21 PM
omlambu's Avatar
Well, that answers one question. Thanks for your answer
Old 12-15-2008, 04:53 PM
Number47's Avatar
chances are you need to clean the ground for the wiper motors and you can return to the correct fuse and probably the same for the interior lights
Old 12-15-2008, 05:34 PM
John Faughn's Avatar
I do not have the fuse location / rating , but would suggest that you do not over rate any of the fuses / but leave the stock rating in all .
Do you have an owners manual ?
If not go to the junk yard and look through all the trucks like yours , then you can see all the location info .
If you are going to keep this truck , then get " only the factory manual " , to get the most info / correct info .
Nothing else is worth buying .
You can get both the hard copy & CD from Geno's Garage .
My link is not the home page .
http://www.genosgarage.com/products.asp?dept=135
Old 12-15-2008, 07:57 PM
omlambu's Avatar
As stated I have already switched back to the stock fuses, and two days so far with rain without any blowing I was just trying to find out if I needed the quad lamp fuse or the security/drl fuse. I know now i do not need the quad lamp fuse but I know I have a security relay. Does that mean I have a security system?
finndogg54
01-18-2008 12:13 PM
Hoser795
11-26-2007 12:04 AM
PEAKSTRYDE
10-11-2007 04:20 PM
Bobcat698
05-03-2007 08:08 AM
TxDiesel007
11-29-2006 12:08 PM
Quick Reply: Questions about my truck "electrical"
